Home > My Range Rover > 2012 Vogue TDV8
Page 5 of 10 <12345678910>
toby1
The fan removal tools are still on the slow boat from China, so I decided to make a start anyway by removing the doughnut. Play stopped early as the plastic engine cover post snapped and I have nothing to remove it.
This connector snapped as I was trying to work out how it came off but still 'clicks' into place, thankfully.
The offending bit of black plastic post:
Halfords here I come.
 2012 Vogue TDV8 in Aintree green over sand
Post #697327 3rd Aug 2024 1:16pm
pcourtney
the passenger side of my engine cover post is also broken, it would be nice to replace it with a new one, as I doubt it will glue back - I wonder if they can be 3D printed, or if possible to buy them ?
Post #697329 3rd Aug 2024 1:52pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Looks like Maltings have them in stock, £5.03
https://maltings4x4store.co.uk/cylinder-he...-lr022884/
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #697364 3rd Aug 2024 8:19pm
pcourtney
thx Andy - I bet they sell a lot of those, and it will be nice to replace the broken one Smile
Post #697377 3rd Aug 2024 9:30pm
toby1
Thanks Andy.
I managed to remove the stub of it with a bit more perseverance and some pliers. However, I do not have a 7mm spanner or socket to remove the nut underneath so more tools ordered off eBay. 2012 Vogue TDV8 in Aintree green over sand
Post #697412 4th Aug 2024 3:50pm
PeteT80
From your picture it looks like the 4 intake hoses have already been fitted with the upgraded ones, the front right doesn’t look to be on properly.
Post #697413 4th Aug 2024 4:38pm
toby1
Your powers of observation serve you well Smile I have unscrewed them all ready to change to the silicon ones I bought in an earlier post. 2012 Vogue TDV8 in Aintree green over sand
Post #697416 4th Aug 2024 6:56pm
toby1
After a short break away I return to carry on with my new sockets, but it is to no avail. These torx screws/bolts will not budge and if I put too much torque they will round off, as I noticed some gorilla has already done to one on other side.
Therefore the doughnut is not coming off for now whilst I search for a way to remove these four without causing major hassle. Very annoying as I have today off to make some progress on it.
Post #697875 12th Aug 2024 12:21pm
JayGee
Do you have an impact driver as it will break the thread bond without applying too much torque - shock vs brute force 2012 TDV8 Vogue (L322)
Post #697877 12th Aug 2024 12:29pm
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
I had the same issue and decided not to risk it, and I left that bracket in place. There are nuts under the bracket that you can reach to release the doughnut.
Post #697879 12th Aug 2024 12:35pm
Baltic Blue
Get 2 nuts, run them down the thread, lock them together, then use the bottom one to remove the stud. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #697880 12th Aug 2024 12:36pm
Richie N
I tried that but the stud was close to snapping so didn’t risk it.
JLR do use a lot of thread lock, I wonder if that’s why they’re stuck? A little heat on the stud might do it…
Post #697882 12th Aug 2024 12:42pm
toby1
OK thanks chaps. Some things to consider. 2012 Vogue TDV8 in Aintree green over sand
Post #697885 12th Aug 2024 12:51pm
JayGee
If they are threaded into the head it will be galvanic corrosion not threadlock. 2012 TDV8 Vogue (L322)
Post #697889 12th Aug 2024 1:16pm
toby1
I liked this idea, I managed to remove one on the right but then two of the four throttle body bolts rounded off so I can't remove it for access. I expected a fight but not chocolate metal.
I have lost my mole grips so I am considering the next plan of attack. I could Dremel notches and use a big screwdriver. It's too warm now in any case so time to chill and gather my thoughts. 2012 Vogue TDV8 in Aintree green over sand
Post #697899 12th Aug 2024 2:51pm
