Home > My Range Rover > 2012 Vogue TDV8 |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 827 |
the passenger side of my engine cover post is also broken, it would be nice to replace it with a new one, as I doubt it will glue back - I wonder if they can be 3D printed, or if possible to buy them ?
3rd Aug 2024 12:52pm |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 585 |
Looks like Maltings have them in stock, £5.03
3rd Aug 2024 7:19pm |
thx Andy - I bet they sell a lot of those, and it will be nice to replace the broken one |
3rd Aug 2024 8:30pm |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 168 |
Thanks Andy.
4th Aug 2024 2:50pm |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 214 |
From your picture it looks like the 4 intake hoses have already been fitted with the upgraded ones, the front right doesn’t look to be on properly. |
4th Aug 2024 3:38pm |
Your powers of observation serve you well I have unscrewed them all ready to change to the silicon ones I bought in an earlier post. 2012 Vogue TDV8 in Aintree green over sand |
4th Aug 2024 5:56pm |
After a short break away I return to carry on with my new sockets, but it is to no avail. These torx screws/bolts will not budge and if I put too much torque they will round off, as I noticed some gorilla has already done to one on other side.
12th Aug 2024 11:21am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
Do you have an impact driver as it will break the thread bond without applying too much torque - shock vs brute force 2012 TDV8 Vogue (L322) |
12th Aug 2024 11:29am |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 334 |
I had the same issue and decided not to risk it, and I left that bracket in place. There are nuts under the bracket that you can reach to release the doughnut. |
12th Aug 2024 11:35am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3778 |
Get 2 nuts, run them down the thread, lock them together, then use the bottom one to remove the stud. G reg 2.5VM Vogue Portofino red 1991- 1999
12th Aug 2024 11:36am |
I tried that but the stud was close to snapping so didn’t risk it.
12th Aug 2024 11:42am |
OK thanks chaps. Some things to consider. 2012 Vogue TDV8 in Aintree green over sand |
12th Aug 2024 11:51am |
If they are threaded into the head it will be galvanic corrosion not threadlock. 2012 TDV8 Vogue (L322) |
12th Aug 2024 12:16pm |
I liked this idea, I managed to remove one on the right but then two of the four throttle body bolts rounded off so I can't remove it for access. I expected a fight but not chocolate metal. I have lost my mole grips so I am considering the next plan of attack. I could Dremel notches and use a big screwdriver. It's too warm now in any case so time to chill and gather my thoughts. 2012 Vogue TDV8 in Aintree green over sand |
12th Aug 2024 1:51pm |
