![]() | Home > Technical (L405) > front knuckle cracking |
Seatown Member Since: 30 Oct 2020 Location: Mountains, seaside Posts: 90 ![]() ![]() ![]() |
Hi Stan, you've probably already noted this one but if not.. https://www.fullfatrr.com/forum/topic65628.html |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35675 ![]() ![]() |
thanks Kevin, thread 'sticky-fied'... |
fenair Member Since: 01 Sep 2021 Location: Norfolk Posts: 47 ![]() ![]() ![]() |
Ladies & gents, i managed to replace the unbroken side front knuckle yesterday, i attach images of the cracks in this one, days , weeks maybe months but not years before it would fail, i strongly urge all you people with a L405 thats 7 years or older or 100,000 miles to A, investigate or B, replace before disaster.
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 521 ![]() ![]() ![]() |
I've only mine a few weeks and I think I am out of range (2018MY) butty good lady was driving us and she has a habit of turning the wheel to full lock while stationary; I always crawl before applying steering. As many of the failures seem to be at low speed, is it damage/wear that is caused when these big heavy lumps are stationary with the steering then applied?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8574 ![]() ![]() ![]() |
Thanks for the write up, glad you got it sorted at a not too bad price... |
Sadly nothing to do with turning the steering wheel stationary or rolling, it's due to chemistry, the reaction of water and salt on the bare unprotected steel pinch bolt holding the top arm ball joint , the corrosion from the steel eats the aluminium knuckle right where it sits, in the thinnest part of the casting, look at the pictures I have posted, the acid residue builds up, and like freezing water in a cast engine block the pressure causes the cast to fracture... Nothing but a |
Range Rover LSE Member Since: 15 Jul 2012 Location: Preston Posts: 46 ![]() ![]() |
Had a light metallic noise on slow manoeuvring decided to have a quick look as I’d been aware of the failures reported on here. Surprised to find a crack given mine is a 2018 vehicle with a VIN well outside the range quoted in another post. Called LR assistance and vehicle recovered and repaired. Thanks for multiple posts by forum members which alerted me to check etc.
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
That’s a real concern on a 2018 |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1322 ![]() ![]() |
This is opening a bigger can of worms! I would be concerned the other side could fail in the very near future and of course warranty repairs they wont touch it unless it's also cracked. Unless common sense prevails |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1696 ![]() ![]() ![]() |
@Range Rover LSE:
Profile updated, thanks for spotting that. I’ve had mine since about 20k, now showing just short of 60k, it does about 15k per year motorways and A roads. No off-roading other than towing caravan onto pitches at 5 van sites. It has full LR service history and leads a “cosseted” life while with me. The other side has been carefully checked and shows no sign of any cracking etc. Also the replacement is to the same design as far as I can see.
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 376 ![]() ![]() ![]() |
What’s the ball park cost of a preemptive replacement? Keep debating about updating to a L405 but this is just another potential issue to consider. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Bob, price for a knuckle is about £700 ish, it comes with a new bearing...
