![]() | Home > Technical (L405) > front knuckle cracking |
Jon Byrne Member Since: 09 Apr 2022 Location: N Ireland Posts: 12 ![]() ![]() |
154JON. You make a great point and something I meant to mention. I checked on TOPIX and if I follow the replacement procedure there, a torque of 70Nm is quoted, adding that you must use a new bolt.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35634 ![]() ![]() |
i suspect the topix '70' is more up to date than the older WM '60'
154JON Member Since: 31 Mar 2019 Location: Essex Posts: 131 ![]() ![]() ![]() |
Hi Stan
My thoughts exactly. The Engineer advised me to use the 60Nm torque although he did say 70 should not make much difference. He observed me torquing them. I had filled the gaps with grease so if the clamp should deform, I would see movement of the grease. I’m not advising as to what torque to use. That will be at your own discretion. I am satisfied that 60Nm is an adequate torque for the clamping joint. |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
No problem, it seems fairly obvious that JLR need to do something about this, especially considering it to be a premium brand, they should have enough in the bank to put it right. Thanks for your investigation and report to DVSA. AJG BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
Griz Member Since: 07 May 2022 Location: Cheshire Posts: 1 ![]() ![]() |
Hi I have had the same problem with the knuckles ,I am female and really don’t know much about cars but in February I was coming off a busy roundabout heard a loud bang and my steering went,I had never been so scared.when I got out of the car the drivers side wheel was bent inwards I had it towed to a local garage where the drive shaft and knuckle were replaced.then a few weeks ago I turned left heard a loud bang and the other side had done exactly the same thing.my bill for both repairs was nearly £5000 .I have a 2015 Range Rover and my vin no falls in this category
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
Griz, have a look at gov.uk/vehicle recalls and faults. Step 1 is to tell the manufacturer. That would be Land Rover itself, rather than (say) a dealer, contact details on the LR website. Step 2 if you are dissatisfied with the response is to report to DVSA through the vehicle recalls and faults site.
It would carry more weight and cost less if all of you on here got together and started a joint action against JLR, It would also be better for DVSA to have a group contact them with the same issue. BMW i3 Electric Car
Brid91 Member Since: 01 May 2019 Location: Rotherham Posts: 13 ![]() ![]() ![]() |
All. I am the originator of this thread and it is now two years since I had the issue and made a case to the DVSA.
Land Rover will fog you off, blaming incorrect torque on the clamping bolt. See how yours has fractured on one side first, which allows accelerated formation of the corrosion same as all the rest? And the gap in the clamping bracket has reduced, same as in all the previous cases I have witnessed. The question remains, why didn’t the garage check the other side when they repaired the first one that had broken. The fracture would have been present on the other side, and the gap would have been visibly reduced and can be seen by the naked eye. I measured the gap at 1.0/ 0.9mm on correctly torqued clamps. If you can’t fit a 0.9 mm “feeler” gauge in the gap of the clamp you must inspect the top clamp thoroughly! It’s going to break off. See my earlier reply on this thread . Jon |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1233 ![]() ![]() ![]() |
Griz, if the garage that renewed the parts was not a dealer or independent specialist I would get a dealer or Indy specialist to check the torque on the new parts / fastenings, as reading the above post from Jon Byrne, if these were over tightened / torqued, then you could end up with the same problem again in the future.
Jeffo66 Member Since: 28 Jun 2022 Location: Penrith, Cumbria Posts: 3 ![]() ![]() ![]() |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
I can't believe that jlr are ignoring this issue and that there hasn't been a recall |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1810 ![]() ![]() |
Look how long its taken them to recall Evoque/Disco Sport steering racks |
