![]() | Home > Technical (L322) > 4.4tdv8 oil light |
Daitdv8 Member Since: 25 Jun 2023 Location: Blackwood Posts: 14 ![]() ![]() ![]() |
30 seconds is worrying |
I'm not worried. 2012 TDV8 Vogue (L322) |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 163 ![]() ![]() ![]() |
that is your car... |
It's my car and I'm not worried. 2012 TDV8 Vogue (L322) |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 415 ![]() ![]() ![]() |
a bit more on DIYing this.
Suchej Member Since: 17 Aug 2023 Location: Prague Posts: 4 ![]() ![]() ![]() |
Hi all, did you ever resolve this issue? Mine is doing exactly the same. Doubt it’s the sensor, as you can clearly hear a slight rattle that goes out at the same time as the light. Thanks a lot |
Never resolved it but always try to park facing down if I have to leave it overnight. 2012 TDV8 Vogue (L322) |
i also similarly have the issue if am pointing facing up towards the hill.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2640 ![]() ![]() |
When pointing uphill the oil level at the front of the sump will be lower so requires more suction to be drawn into the pump then pumped until resistance is achieved by getting to the various shaft bearings. The oil is almost at the top of the front of the sump when the vehicle is level. |
Yeah that makes sense. Also, it rarely does it after an oil change. Up to I’d say 4k miles then it appears again. Also had an engine rebuilt with both new turbos about 8k miles ago, never had this issue before.
