Home > Technical (L322) > 4.4tdv8 oil light |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1380 |
Good news is it's right at the top and front of the engine by the auxiliary belt, above the upper left pulley (as seen facing the engine bay).
25th Jun 2023 10:29pm |
Daitdv8 Member Since: 25 Jun 2023 Location: Blackwood Posts: 14 |
Hello
25th Jun 2023 10:47pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2845 |
I get low oil pressure on cold startup if I park on a steep uphill slope. It's not a sensor fault as it never happens on the level. 2012 TDV8 Vogue (L322) |
26th Jun 2023 7:48am |
Thats how mine started, now doing it on level too. |
26th Jun 2023 7:50am |
How many miles on your engine? 2012 TDV8 Vogue (L322) |
26th Jun 2023 8:31am |
108k
26th Jun 2023 1:33pm |
AFAIK the level sensor displays a low oil text info on the dash. The 'oil can' light on the instrument is low pressure. 2012 TDV8 Vogue (L322) |
26th Jun 2023 1:45pm |
If of any assistance, the oil level sensor is on the bottom of the sump (I saw it today whilst changing the diff oils).
26th Jun 2023 4:22pm |
Thank you I'm going to change the sensor, I'm not overly worried but it didn't do it before. Tested the oil pressure on cold start and its spot on. |
26th Jun 2023 7:15pm |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 183 |
Mine does this too, when parked on level or on incline.
26th Jun 2023 9:23pm |
On a slope mine comes on a few seconds after starting and lasts quite a few seconds accompanied by a definite rattling noise from the engine which stops as soon as the light goes out so I doubt it's the sensor on mine at least. I've had it happen on the level when I drained the oil from cold. I got nearly 1L more out than when doing a hot drain so likley quite a bit of oil is in the upper engine which drains down overnight and it's quite a long way to pump it back up again. Cold starts with thick oil generate max oil pressure but slowest circulation times so I think it's nothing to worry about. I never blip the throttle and always idle for 30 seconds before engaging drive in the mornings. An oil light showing on a hot engine at idle would be a big worry though..... 2012 TDV8 Vogue (L322) |
26th Jun 2023 9:38pm |
Just thought I'd update
1st Jul 2023 8:46am |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 364 |
Mine does same.
2nd Jul 2023 5:51pm |
Yes its LR000633 |
2nd Jul 2023 6:03pm |
