Home > Technical (L322) > 4.4tdv8 oil light
Page 2 of 3 <123>
mgrover
Awesome, ordered.
Is it 1 or 2 sensors?
Cheers Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #668152 2nd Jul 2023 6:26pm
Daitdv8
Just the one, to the left as you look at the engine. Make sure its torqued up
Post #668153 2nd Jul 2023 6:28pm
Yellopin
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
Hi all. I too have just started to have the light come on, about 5 seconds after engine started. It stays on for maybe 1-2 seconds and only on first start of the day and not when hot. Thought maybe dilution (I disturbed throttle housing seal whilst changing to silicone doughnuts and had to do a few mods to reseal following dpf issues, preventative caused me corrective….doh!) but it’s at 4.6 dilution so maybe not? I’ve got a new sensor to fit and not due oil change for a few thou. Might just replace oil and filter anyway and replace sensor whilst at it. Not much out there regarding this fault and only code on car is EGR (EGT) usual one. Just putting out there for the ones collecting fault records. Fingers crossed I’m as lucky as you guys and the above fixes it?
Cheers 2011 4.4 TDV8 Autobiography Ipanema sand
2007 3.6 TDV8 RRS HSE Black
2003 4.6is V8 BMW X5 Black
2000 2.5 TD5 Discovery Blue
2000 1.8 Freelander Black
Post #668759 9th Jul 2023 8:20pm
mgrover
genuinely am struggling to find it Laughing
could you take a picture of it in the context of the engine bay when you get a chance please. Its actually a sport Sad
Post #670697 8th Aug 2023 8:59am
Daitdv8
Sure
It's directly under this, mine has started doing it again though. Changed the battery aswell so I'm just going to embrace it as a feature.
Post #670698 8th Aug 2023 9:05am
mgrover
now thats where it may get more worrying and make me start wondering about the oil pump. Its actually a sport Sad
Post #670699 8th Aug 2023 9:13am
Daitdv8
If its a split second in the morning I wouldn't stress, if it comes on when hot then I'd burn it.
Post #670700 8th Aug 2023 9:15am
mgrover
its always morning and when cold thankfully. Its actually a sport Sad
Post #670702 8th Aug 2023 9:19am
JayGee
Is there an 'anti drain back' valve in the system (oil filter housing?) 2012 TDV8 Vogue (L322)
Post #670703 8th Aug 2023 9:29am
Daitdv8
I've not actually looked into that
Post #670704 8th Aug 2023 9:44am
kevinp
Underneath the oil filter is a 'leaf spring' which I think is an anti drain device.
When I did my first oil change mine was loose in the bottom of the housing.
If I remember rightly it sits on a post with 'gripper teeth'.
I think this is why you loosen the filter to lift the 'spring' so the filter can drain.
Worth checking.
Post #670713 8th Aug 2023 10:57am
JayGee
Good bit of info. Never looked down there but will next oil change. 2012 TDV8 Vogue (L322)
Post #670714 8th Aug 2023 11:17am
mgrover
the only thing I can see in that location is something plugged into the vacuum pump, is that normal? Its actually a sport Sad
Post #670715 8th Aug 2023 11:19am
Daitdv8
It's to the left of the turbo boost solenoid, you'll need to move a few wires to see it.
Post #670716 8th Aug 2023 11:23am
Daitdv8
Just a thought
Has anyone had the oil cooler replaced before this happening?
Post #671053 12th Aug 2023 9:37pm
Page 2 of 3 <123>
