Home > Technical (L322) > 4.4tdv8 oil light
Page 3 of 3 <123
JayGee
Parked facing uphill on a steep incline last night and this morning the oil light took a good 30 seconds to go out. 2012 TDV8 Vogue (L322)
Post #671104 13th Aug 2023 5:47pm
Daitdv8
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
30 seconds is worrying
Post #671105 13th Aug 2023 5:49pm
JayGee
I'm not worried. 2012 TDV8 Vogue (L322)
Post #671106 13th Aug 2023 6:19pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
that is your car...
Post #671128 13th Aug 2023 11:40pm
JayGee
It's my car and I'm not worried. 2012 TDV8 Vogue (L322)
Post #671133 14th Aug 2023 7:05am
mgrover
a bit more on DIYing this.
Unrelated to this I had removed the vacuum pump, the gasket had been leaking so thought Censored it time to change.
Made life a billion times easier to change the oil sensor.
Basically it went:
A. Airbox out
B. Screw holding that pipe out
C. 2 bolts and 1 nut for vacuum pump.
D. Sensor is right there.
It's defo more work than just going for it but hey ho.
Also be careful with the vacuum pipes. When I was carelessly checking I don't think I put them back well and hey ho one of the vacuum pipes got clipped by the fan and I've been chasing restricted performance issues. Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #671627 21st Aug 2023 9:39am
Suchej
Czech Republic 2011 Range Rover Vogue TDV8 Barolo Black
Hi all, did you ever resolve this issue? Mine is doing exactly the same. Doubt it’s the sensor, as you can clearly hear a slight rattle that goes out at the same time as the light.
Thanks a lot
Post #701339 3rd Oct 2024 6:50am
JayGee
Never resolved it but always try to park facing down if I have to leave it overnight. 2012 TDV8 Vogue (L322)
Post #701350 3rd Oct 2024 9:01am
mgrover
i also similarly have the issue if am pointing facing up towards the hill.
never managed to resolve it Its actually a sport Sad
Post #701351 3rd Oct 2024 9:04am
GraemeS
Australia
When pointing uphill the oil level at the front of the sump will be lower so requires more suction to be drawn into the pump then pumped until resistance is achieved by getting to the various shaft bearings. The oil is almost at the top of the front of the sump when the vehicle is level.
Post #701356 3rd Oct 2024 10:40am
Suchej
Yeah that makes sense. Also, it rarely does it after an oil change. Up to I’d say 4k miles then it appears again. Also had an engine rebuilt with both new turbos about 8k miles ago, never had this issue before.
Just started it when it stayed for a day and a half facing slightly downwards. No light, rattle gone in about 1 sec after start.
Post #701360 3rd Oct 2024 10:52am
Page 3 of 3 <123
