![]() | Home > My Range Rover > Back with another Supercharged! A 5.0 this time! |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3195 ![]() ![]() ![]() |
Car is now back out of the workshop!
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8533 ![]() ![]() ![]() |
Top job as always, lets hope that's the last thing you have to do before the warmer weather starts....!! |
CaifanSC Member Since: 25 Dec 2018 Location: Maryland Posts: 30 ![]() ![]() ![]() |
David, amazing read! I'm going through both threads; for this car and the black supercharged Rangie you had.
When I did my subframe it was a lot of work. Painting with the 2 part epoxy mastic was hard work as the paint was heavy and it killed brushes.
The 5.0 hit a milestone on Tuesday morning.
Good luck with the MOT but I doubt you will need it... |
I dropped the SC off with the local specialist for it's MOT yesterday. Whilst I was waiting to be picked up, they took the car round the corner for its MOT.
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 513 ![]() ![]() ![]() |
a well looked after and largely original L322 is indeed a lovely sight First time FFRR owner |
Since I've had this 5.0, every time the fuel light comes on the dash shows approximately 50 miles of range but I can only get 80 odd litres in the tank. The manual states that it's a 101 litre tank so I'd expect to be able to get more then 80 lites in it when the light comes on.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1810 ![]() ![]() |
Done hundreds of these on D4/RRS, but usually gives a 0 range when the fuel level drops a bit |
Hmm, I feared that might be the case.
If it's any consolation, I've a Jag XF that runs out of fuel at ΒΌ tank remaining. I remaining hopeful it's also an easy fix |
A friend of mine has a 2007 TDV8 that does exactly that! I've got enough problems of my own without taking on other peoples issues at the moment. |
camaro8199 Member Since: 18 Feb 2025 Location: South Carolina Posts: 4 ![]() ![]() ![]() |
How did you remove the supercharger. I have mine loose and tilted but am hung up in the back by something. Can you tell me what needed to be unhooked in the rear? |
