![]() | Home > Maintenance & Mods (L405) > 4.4 coolant pipe o-ring replacement pics |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 363 ![]() ![]() ![]() |
I’ve done the oil cooler btw so it’s not that. The UV dye is a great idea 👍 |
Hi Chris, did the coolant find its way to the rear of the engine and down the bellhousing? |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 139 ![]() ![]() ![]() |
I am not sure where the coolant ended up. I knew I had a coolant leak, and upon investigation I could see it dropping from the bottom of one of those two front joints into the valley.
L9ups Member Since: 20 Sep 2024 Location: Sydney Posts: 3 ![]() ![]() ![]() |
I had the o-rings leak and I couldn’t find the smaller o-ring pipe sizing anywhere online, if anyone is wondering it was 19mm x 2.65mm |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 501 ![]() ![]() ![]() |
Great right up….the rubber seal size 45mm is that the internal size or external size ?
The 45mm is the id of the o-ring, and I’d suggest to do all 3 o-rings at the same time as I had one of the bigger ones leak and so I replaced both one of which looked like had been recently replace which wasn’t the one leaking and then was alright for a day then the smaller one in the middle started leaking. |
I used a 19mm x 2.65mm which I had in a viton o-ring kit which worked fine |
Great thanks |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3192 ![]() ![]() ![]() |
Sorry to revive this…
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 234 ![]() ![]() |
Yes, the two large ones are the same size. 2012 Vogue TDV8 in Aintree green over sand |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 900 ![]() ![]() ![]() |
thank you fisha - great write up, replaced my o-rings today and no more coolant leak, which is great news and saved me over £100 in the process |
