Home > Maintenance & Mods (L405) > 4.4 coolant pipe o-ring replacement pics
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
I’ve done the oil cooler btw so it’s not that. The UV dye is a great idea 👍
Post #687647 9th Mar 2024 8:23pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
I had the same issue, although I resolved it with new pipes as I didn't know what size the o-ring was.
I wonder if we should compile a full list of o-rings used in the cooling system so a kit can be put together.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #687665 10th Mar 2024 8:44am
Richie N
Hi Chris, did the coolant find its way to the rear of the engine and down the bellhousing?
Post #687666 10th Mar 2024 8:55am
ChrisJC
I am not sure where the coolant ended up. I knew I had a coolant leak, and upon investigation I could see it dropping from the bottom of one of those two front joints into the valley.
P38 - 4.6V8 HSE
Post #687667 10th Mar 2024 8:57am
L9ups
Australia 2016 Range Rover HSE SDV8 Santorini Black
I had the o-rings leak and I couldn’t find the smaller o-ring pipe sizing anywhere online, if anyone is wondering it was 19mm x 2.65mm
Post #700534 20th Sep 2024 9:50pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
Great right up….the rubber seal size 45mm is that the internal size or external size ?
Thanks will
Post #701047 29th Sep 2024 3:21am
L9ups
The 45mm is the id of the o-ring, and I’d suggest to do all 3 o-rings at the same time as I had one of the bigger ones leak and so I replaced both one of which looked like had been recently replace which wasn’t the one leaking and then was alright for a day then the smaller one in the middle started leaking.
Post #701048 29th Sep 2024 3:23am
will308f
Thumbs Up yea makes sense what’s the size of the smaller seal
Post #701049 29th Sep 2024 3:29am
L9ups
I used a 19mm x 2.65mm which I had in a viton o-ring kit which worked fine
Post #701050 29th Sep 2024 3:39am
will308f
Great thanks
Post #701052 29th Sep 2024 3:57am
dhallworth
Sorry to revive this…
Are both of those pipes into the thermostat the same size seals on the 4.4?
Thanks
Post #704521 15th Nov 2024 4:28pm
toby1
Yes, the two large ones are the same size. 2012 Vogue TDV8 in Aintree green over sand
Post #704557 16th Nov 2024 10:01am
