Home > Maintenance & Mods (L405) > 4.4 coolant pipe o-ring replacement pics |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 349 |
I’ve done the oil cooler btw so it’s not that. The UV dye is a great idea 👍 |
9th Mar 2024 8:23pm |
Hi Chris, did the coolant find its way to the rear of the engine and down the bellhousing? |
10th Mar 2024 8:55am |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 129 |
I am not sure where the coolant ended up. I knew I had a coolant leak, and upon investigation I could see it dropping from the bottom of one of those two front joints into the valley.
10th Mar 2024 8:57am |
L9ups Member Since: 20 Sep 2024 Location: Sydney Posts: 3 |
I had the o-rings leak and I couldn’t find the smaller o-ring pipe sizing anywhere online, if anyone is wondering it was 19mm x 2.65mm |
20th Sep 2024 9:50pm |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 448 |
Great right up….the rubber seal size 45mm is that the internal size or external size ?
29th Sep 2024 3:21am |
The 45mm is the id of the o-ring, and I’d suggest to do all 3 o-rings at the same time as I had one of the bigger ones leak and so I replaced both one of which looked like had been recently replace which wasn’t the one leaking and then was alright for a day then the smaller one in the middle started leaking. |
29th Sep 2024 3:23am |
yea makes sense what’s the size of the smaller seal |
29th Sep 2024 3:29am |
I used a 19mm x 2.65mm which I had in a viton o-ring kit which worked fine |
29th Sep 2024 3:39am |
Great thanks |
29th Sep 2024 3:57am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3131 |
Sorry to revive this…
15th Nov 2024 4:28pm |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 179 |
Yes, the two large ones are the same size. 2012 Vogue TDV8 in Aintree green over sand |
16th Nov 2024 10:01am |
