![]() | Home > Maintenance & Mods (L405) > 4.4 coolant pipe o-ring replacement pics |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Really good information 👍
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 774 ![]() ![]() ![]() |
Well done fisha |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Thanks for the detailed description |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1311 ![]() ![]() |
Its a morning of rings and Knobs |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1163 ![]() ![]() ![]() |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1458 ![]() ![]() |
You’re welcome. Managed to get the coolant system bled which was a real PITA, but got there eventually. V8 or else ... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8529 ![]() ![]() ![]() |
Super writeup... Alas I won't be able to do it as I don't have any socks.... |
You could use some old knickers Pete? overfinch modified |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1672 ![]() ![]() ![]() |
And LUBE, don’t forget lube! ![]() |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1232 ![]() ![]() ![]() |
As I was puzzled, I googled 'Lovehoney lube' Having been divorced and single for some years now, lets just say that it was an educating few minutes, |
Lol. I’ve had it for years. Cause its water based it shouldn’t affect the coolant or internals. It’s been useful over the years for getting hoses to fit over pipes and things like that. It’s almost run out now, so I’m not sure how i will get it past the “what’s that you’ve bought for the car now?” budget filter of the wife ! |
I forgot to add, nice write up Fisha |
Silicone grease is what you need to stay out of er, trouble.
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 363 ![]() ![]() ![]() |
Nice write up. Where was the leak ? I’ve got coolant running down the bellhousing, could it be from those pipes? I think water is collecting in the V on mine, and then escaping out the back.. |
