Home > Maintenance & Mods (L405) > 4.4 coolant pipe o-ring replacement pics
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
I’ve done the oil cooler btw so it’s not that. The UV dye is a great idea 👍
Post #687647 9th Mar 2024 8:23pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
I had the same issue, although I resolved it with new pipes as I didn't know what size the o-ring was.
I wonder if we should compile a full list of o-rings used in the cooling system so a kit can be put together.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #687665 10th Mar 2024 8:44am
Richie N
Hi Chris, did the coolant find its way to the rear of the engine and down the bellhousing?
Post #687666 10th Mar 2024 8:55am
ChrisJC
I am not sure where the coolant ended up. I knew I had a coolant leak, and upon investigation I could see it dropping from the bottom of one of those two front joints into the valley.
P38 - 4.6V8 HSE
Post #687667 10th Mar 2024 8:57am
L9ups
Australia 2016 Range Rover HSE SDV8 Santorini Black
I had the o-rings leak and I couldn’t find the smaller o-ring pipe sizing anywhere online, if anyone is wondering it was 19mm x 2.65mm
Post #700534 20th Sep 2024 9:50pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
Great right up….the rubber seal size 45mm is that the internal size or external size ?
Thanks will
Post #701047 29th Sep 2024 3:21am
L9ups
The 45mm is the id of the o-ring, and I’d suggest to do all 3 o-rings at the same time as I had one of the bigger ones leak and so I replaced both one of which looked like had been recently replace which wasn’t the one leaking and then was alright for a day then the smaller one in the middle started leaking.
Post #701048 29th Sep 2024 3:23am
will308f
Thumbs Up yea makes sense what’s the size of the smaller seal
Post #701049 29th Sep 2024 3:29am
L9ups
I used a 19mm x 2.65mm which I had in a viton o-ring kit which worked fine
Post #701050 29th Sep 2024 3:39am
will308f
Great thanks
Post #701052 29th Sep 2024 3:57am
dhallworth
Sorry to revive this…
Are both of those pipes into the thermostat the same size seals on the 4.4?
Thanks
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #704521 15th Nov 2024 4:28pm
toby1
Yes, the two large ones are the same size. 2012 Vogue TDV8 in Aintree green
Post #704557 16th Nov 2024 10:01am
