Home > Maintenance & Mods (L322) > Restricted performance 4.4 tdv8
Page 4 of 4 <1234
mgrover
whats it go into Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #679140 30th Nov 2023 2:55pm
BeneVato
Georgia 2012 Range Rover Vogue 4.4 V8 Santorini Black
I attached picture.
Post #679142 30th Nov 2023 2:57pm
mgrover
sorry I mean other end. Its actually a sport Sad
Post #679145 30th Nov 2023 2:58pm
BeneVato
It's from vacuum solenoid.
Post #679146 30th Nov 2023 3:01pm
BeneVato
Can anyone share vacuum pipe detailed diagram? For 2012 range Rover 4.4 TDV8.
All drowning witch I find on a internet is only pipes with code doesn't showing where to connect it.
Please if anyone has detailed diagram share to me.
Post #679194 1st Dec 2023 8:43am
GraemeS
Australia
The way that mine heads backwards after dropping down the front, I suspect it is LR022879 which connects to the turbo. I would have to remove the sump cover to confirm where it ends-up.
Post #679195 1st Dec 2023 9:11am
Charles159621
United Kingdom 2012 Range Rover Westminster TDV8 Stornoway Grey
Hello I’ve had these codes since owning my car, I’ve had it about 4/5 months, I’ve checked the actuator and it’s moving freely, however it is the old style with the nut on top, I’ve just got a new vacuum hose for the actuator to see if that makes a change
The plug I’ve found seemed to be unplugged and that leads down to the “solenoid” next to actuator, plugging back in and running the car has made no difference, still getting the code and the limp mode up a hill on constant speed. The code obviously saying circuit open, I can’t see any obvious damage to wires and it’s all connected ???
Could the solenoid need replacing ?
If so would anyone have a part number for it by any chance
Some amazing advice so far on this matter
Any help or experience on my variant of this issue is massively appreciated thankyou
Post #686166 21st Feb 2024 10:11pm
mgrover
id take the solenoids off and apply 12v to them, if they click, id fire in some carb cleaner and keep toggling them on/off.
probs worth replacing all the pipes with rubber Its actually a sport Sad
Post #686193 22nd Feb 2024 10:11am
GraemeS
Australia
The solenoid mounted on the shut-off valve is part of the shut-off valve, not a separate part.
Post #686199 22nd Feb 2024 11:03am
Page 4 of 4 <1234
