![]() | Home > Maintenance & Mods (L322) > Restricted performance 4.4 tdv8 |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 415 ![]() ![]() ![]() |
whats it go into Its actually a sport |
BeneVato Member Since: 30 Nov 2023 Location: Tbilisi Posts: 4 ![]() ![]() ![]() |
I attached picture.
sorry I mean other end. Its actually a sport |
It's from vacuum solenoid.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2554 ![]() ![]() ![]() |
The way that mine heads backwards after dropping down the front, I suspect it is LR022879 which connects to the turbo. I would have to remove the sump cover to confirm where it ends-up. |
Charles159621 Member Since: 21 Feb 2024 Location: Hampshire Posts: 1 ![]() ![]() ![]() |
Hello I’ve had these codes since owning my car, I’ve had it about 4/5 months, I’ve checked the actuator and it’s moving freely, however it is the old style with the nut on top, I’ve just got a new vacuum hose for the actuator to see if that makes a change
id take the solenoids off and apply 12v to them, if they click, id fire in some carb cleaner and keep toggling them on/off.
The solenoid mounted on the shut-off valve is part of the shut-off valve, not a separate part. |
