![]() | Home > Maintenance & Mods (L322) > Restricted performance 4.4 tdv8 |
Oakesy2001uk Member Since: 18 May 2022 Location: Cheshire Posts: 16 ![]() ![]() ![]() |
Amazing thanks - i’ll pull them off tomorrow, measure and make up
One had a small clip on the edge of where the hose clamp is… very much hoping thats my problem! I’ll measure up for silicone ones now. Wouln’t have thought that would cause a leak where it is though…. Hopefully it has.
Worth changing them but it shouldn't leak from there as it's on the outside of the clamp. 2012 TDV8 Vogue (L322) |
Rubbish - that was my thinking. I’ll swap them anyway.
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
I would give the plenum and MAF sensors a good clean before putting everything back together. Maybe check the plenum for any signs of a split.
Hard to say there was so much mess oily residue around/in the plenum anyway. I thought there might be some soot but minimal.
Any black oily stuff outside the plenum means you have a leak. The throttle body to intake seal sometimes leaks as well and it's a push fit and lip seal with a retaining clip so not as secure as the intake to plenum connectors. 2012 TDV8 Vogue (L322) |
Thats probably the muckiest bit to be honest at the front, rest not to bad so that might be a favourite, the seal point in a little and is grubby - i assume its worth changing if i can find a part number. I’ll clean it all up, change the hoses for silicone hoses as well and see where we are - just waiting on hoses now. |
Just cleaning the donut whilst its off…
Cleaned it all out, 4 new hoses etc… etc…. Still going into restricted the 2nd or 3rd time you push the throttle hard on a drive. No change.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
CSOV check next
If the csov is the changeover valve… i reached it and can opening it squeezing with my fingers… no bolt on top so its the revised one… moving eith hands doesn’t mean its working i suppose |
Codes are still as follows….
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1209 ![]() ![]() ![]() |
I had that code it is the solenoid to the second turbo, I Changed it out and it has made a big difference to the pickup.
