![]() | Home > Maintenance & Mods (L322) > Restricted performance 4.4 tdv8 |
Oakesy2001uk Member Since: 18 May 2022 Location: Cheshire Posts: 16 ![]() ![]() ![]() |
Sounds exactly like my issue….
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1209 ![]() ![]() ![]() |
That's right it`s not stuck just not activating? the unit solenoid is a JLR part that is located before the turbo,
ciaranshier Member Since: 03 Apr 2023 Location: Wakefield Posts: 4 ![]() ![]() ![]() |
Firstly - thanks everyone for the incredible level of info and help on this forum. 6 months in to my ffrr ownership and loving it so far. I have a RP issue when revving over 2500 and second turbo just not kicking in at all. Same error codes as posted on this thread.
I did not do the work myself the part was supplied by the indie,
Nice one thank you. |
For info - mine was degraded vac pipes, I put a whole new vacuum harness on, although I’m sure you could have just fixed the dodgy bit. Looks like an oil leak in the past caused it. |
Brilliant thank you. I’ll definitely check that as well while I’m in there. |
Thanks again for everyones help on here. Problem resolved - one of the vacuum hoses was collapsing. Had it replaced at an independent and now its running fine. I've only had the car 6 months and on reflection I dont think the second turbo has kicked in the whole time I've had it. Mainly because I've only pushed the car beyond 2400rpm a few times.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Great news and thanks for updating to add to the forum knowledge for future reference 👍 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1291 ![]() ![]() ![]() |
It would be interesting to know the locations of the hoses that are starting to degrade. There's dozens of them. |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 818 ![]() ![]() |
Is there a part number for the vacuum harness or of the individual hoses that need replacing? |
Common procedure for old Turbo cars was to replace all vac/boost control hoses with silicone which resisted age/ heat/oil deterioration. 2012 TDV8 Vogue (L322) |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 415 ![]() ![]() ![]() |
hmm am facing this at the moment.
BeneVato Member Since: 30 Nov 2023 Location: Tbilisi Posts: 4 ![]() ![]() ![]() |
