![]() | Home > General > What Did You Do In Your Full Fat Today |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 655 ![]() ![]() ![]() |
Finished changing out my leaking oil cooler for new Nissins unit today, bought new gaskets but didn't need them as the new unit came complete, so some spares up for grabs, I'll put up for sale at a discount later.
Replaced front diff oil, not sure when it was last done, nothing in the records, but man, the oil that came out stank to high heaven.
Doonhamer Member Since: 07 Jul 2017 Location: Thatcham, Berkshire Posts: 209 ![]() ![]() ![]() |
Just dropped my motor off at Newbury Transmissions for a gearbox service, got 110k on the speedo and wasn’t done by previous owner so I thought a bit of preventive maint might be a good thing. L322 TDV8 4.4 - current
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2279 ![]() ![]() ![]() |
Replaced rear antiroll bar links trailing arms shocks ns hub and bearing all good |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 608 ![]() ![]() ![]() |
Collected from MOT with a "Pass with Defects", never had one of those before.
StuManchu Member Since: 31 Dec 2023 Location: Leicester Posts: 43 ![]() ![]() ![]() |
Booked it in for a new windscreen after a stone flew off a tipper and cracked it, £100 through my insurance... |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 363 ![]() ![]() ![]() |
My 2013 has only done 2k miles since last oil change but when I checked the oil level recently it appeared to have gone up. And I was getting a service message.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
Yesterday, Friday,
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 169 ![]() ![]() ![]() |
Visited the Game Fair at Blenheim Palace. Car park was full of JLR products but no sponsorship or even a stand in the show itself. The Ineos Grenadier had a heavy presence however. |
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 117 ![]() ![]() ![]() |
Spent some time doing some diagnostics today.Looks like the FBH needs fixing/replacing. Another thing on the list. |
Took the plunge and replaced all the mounting fixings on both the engine undertray and the underchin cover with stainless ones.. Also whilst they were off treated the entire subframe and area again in Nitromors rust treatment, undersealed everything steel with Tetroseal and Waxoyled the lot including inside the subframe tubes where possible.
MarkO73 Member Since: 01 Sep 2023 Location: Pembrokeshire Posts: 9 ![]() ![]() ![]() |
Made the most of a dry day. Polished both front headlights and fitted an original 2007 front grille I managed to find on EBay. Finished off by putting Lanoguard underneath. Next, painting front brake callipers. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3260 ![]() ![]() ![]() |
Had a replacement tyre fitted for the one that was totally wrecked on Tuesday by a pothole with an adjacent broken kerb. |
Just messing about with the GAP tool today, decided to offset the woeful DRL on the 2012 models by setting the DRL in GAP to Scandinavian Mode, so lights are on all the time front & rear.
