Home > Maintenance & Mods (L405) > Just in time for winter...remote climate retrofit
Page 6 of 8 <12345678>
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
Yes, should be a 2 minute job now when the bits arrive Thumbs Up Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
Post #603913 16th Aug 2021 12:47pm
knwatkins
marsie wrote:
Just ordered the module and remote for mine, already done the CCF edit and got the timed climate option on the screen so just need to wait for the bits to turn up now. Then wait for cold weather Mr. Green
Paid a bit more for the bits (£70 for the module and £30 for a new key fob) but still a cheap mod Bow down
Thanks for the info and writeup Kev, another gadget added to the list Rolling with laughter
Paul
No probs Paul Thumbs Up
It's useful little mod and having had the functionality on my old RRS, it's something I cannot do without now! Wink Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #603948 16th Aug 2021 6:31pm
marsie
I had it on my D4 and I think when the cold weather comes I would miss it too. Its nice not having to wait to defrost windows Mr. Green Paul
Post #603951 16th Aug 2021 6:54pm
marsie
All done, fitted and programmed and wiring for the snow Mr. Green . Thanks again to Kev for the writeup Thumbs Up Paul
Post #605875 7th Sep 2021 9:02pm
154JON
United Kingdom 2015 Range Rover Vogue SDV8 Santorini Black
Had all summer to sort my retro heating fit after i didnt getting it going last winter due to an open circuit on the aux water pump but i thought i would wait till i could stand in the cold again to try and sort it Rolling Eyes , would anyone know if 12v and an earth should bring the pump to life, i have noticed on pictures of the pump that it has 3 pins in the plug socket but only 2 wires feed it. Thanks for any info.
Post #608539 7th Oct 2021 7:39am
G3 TUC
United Kingdom 2014 Range Rover Vogue SE SDV6 Causeway Grey
Hi all fitted the parts and paired remote but it will only work if am stood next to back piller any one any ideas as to why
Thanks
Post #618865 5th Jan 2022 1:49pm
Fifth Horseman
Scotland 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Check the antenna connections
Post #619130 7th Jan 2022 5:08pm
knwatkins
I don't get a very good range on mine to be honest. It's fine for my needs, and will work between my hallway and car, but if I move into my kitchen, it doesn't reach. On my old L320, the range was crazy. I could have been in the middle of the supermarket and it would reach out to the car park. Kev
Post #619132 7th Jan 2022 5:14pm
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
stan wrote:
thanks Kev, added to our wiki..
This is bloody genius!
Thank you, Kev.
Will be checking if I have FBH and, if I do, I feel an upgrade coming on. What do I put here then?
Post #619144 7th Jan 2022 8:34pm
knwatkins
No problem Thumbs Up
Just on the range issue, what I didn't check was that the coax antenna cable is actually plugged into the TV amplifier module at the other end. It may not be if remote climate wasn't installed at the factory! If anyone checks this and finds out, please report back and I'll update the tutorial. Kev
Post #619154 7th Jan 2022 9:34pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
this any help?
https://www.webasto.com/fileadmin/webasto_...rt-t91.pdf
Post #619794 13th Jan 2022 10:17am
GAC23
knwatkins wrote:
The next step is to update the CCF using a suitable diagnostic tool. For me, as I have the GAP IID tool, I used this and configured the following parameters:
Car Config > BCM-Body Control > Fuel Burning Heater > Fuel Fired Parking Heater
Car Config > BCM-Body Control > Timed Climate > Fitted
This morning's frozen FF reminded me to at least do this bit.
All looks good. Have set it to run tomorrow morning as a test.
Assuming it works - can't see why it won't - I'll be buying the bits to add the remote.
Thanks again for this @knwatkins it's a great post. What do I put here then?
Post #619824 13th Jan 2022 2:56pm
GAC23
Ran my test timed climate this morning.
Got into the car after 25 mins of the FBH running and ...
... air was being blown around the car but the windscreen was still frozen solid.
Looking at the bonnet, the corner over the FBH was defrosted, so have to assume the heater was running.
Did I just not give it enough time? What do I put here then?
Post #619938 14th Jan 2022 10:45am
knwatkins
Strange. My windscreen is always defrosted by the time I get out to the car. Mind you, I think last night was particularly chilly. Just whack your heated front screen on. Should be melted in a few minutes Thumbs Up Kev
Post #619993 14th Jan 2022 10:05pm
GAC23
My L322 used to always clear the screen too.
I think - well hope - you’re right about last night being so cold.
Going to give it another test on the next frosty night, making sure it gets its full run time. What do I put here then?
Post #620028 15th Jan 2022 10:12am
