Home > Maintenance & Mods (L322) > Plastic sill removal.
Page 6 of 7 <1234567>
nfm
2008 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Did mine as well this last few days and very similar condition to sumshiftguy (mine’s a 2008). Was able to reuse all clips no problem. One thing; I was missing the foam blocks - what are they for and if necessary (assume so?) anybody know the part number.
Thanks.
Post #551961 28th Apr 2020 3:21pm
DrRob
The foam blocks appear to fill a void between the end of the sill and the end of the plastic sill cover and stop muck accumulating. Maybe only later ones had them fitted. Not sure Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #551972 28th Apr 2020 4:13pm
Anvil
fanders wrote:
Nice looking Supercharged Rangie!
Why thank you sir!
Post #551974 28th Apr 2020 4:18pm
Anvil
Weren't any on mine and that's a 2006.
Si.
Post #551975 28th Apr 2020 4:19pm
nfm
Thanks, sounds like maybe mine didn’t have them then; certainly the sill covers didn’t look like they had been off before.
Post #551976 28th Apr 2020 4:29pm
kevinp
DrRob wrote:
kevinp wrote:
DrRob wrote:
Post a picture of your modified trim before you fit it Bow down
Me and technology don't go together mate. I'll ask my daughter to post a picture in a bit. Neutral
Kev - any luck with a picture of your mod? I'm intrigued Whistle Thumbs Up
Ay up Rob. I will try and post some photos mate. Things didn't quite work out! I ordered 1 meter of the seal for each side thinking there would be plenty to do the kink. 1 meter is only just long enough to cover the whole arch without cutting for the kink!!!! It does look nice though fitted and virtually covers all the metal lip. Search Amazon,' TMH large u section 21mm x 8mm.'
Post #552019 29th Apr 2020 2:24am
DrRob
Freelander 2 trims fitted on leading edge of rear wheel arch
Door shut
Door open
The residue is dried clear waxoyl. Need to tidy it up a bit Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #552423 2nd May 2020 12:02pm
Fox889
Not the best of photo's to be honest, but shows the door open then closed & using standard non Freelander 2 trims.
There's a minute gap between the new trim & the actual door trim, enough to cause stone chips?.......I dunno.
We'll 'suck it & see' what happens when we eventually get back on the road in a short while [I hope].
 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #552455 2nd May 2020 5:33pm
DrRob
That small gap is why I swapped to FL2 trims but I’m an OCD c u next Tuesday Rolling with laughter Rolling with laughter Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #552485 2nd May 2020 9:53pm
kevinp
My phone camera is a bit crap but you might be able to see what iv'e done. My first attempt to send a picture!!
Post #552528 3rd May 2020 2:26pm
DrRob
Nice. Got a picture of the kinky bit in situ on the car? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #552535 3rd May 2020 3:30pm
kevinp
Post #552602 4th May 2020 10:39am
DrRob
Ingenious Thumbs Up
I might cut a small piece of spare FL2 trim to fit... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #552603 4th May 2020 10:48am
drakes
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
What are people using to "fill" the trims before fitting. I did mine last year and filled them with grease but when I had a sneaky look today the grease has gone. Is there a "solid" version of waxoyl type product that could be used. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2005 4.4V8 (M62) Bonatti Grey/ Parchment interior - gone
1998 4.6HSE Blue/ Cream interior (can't remember exact colours) - gone
1977 White - gone (should have kept)
Post #555799 29th May 2020 4:37pm
Weegie
I used Bilthamber wax for my tailgate. Injected using the "straw" provided. They have a number of products. Better than grease IMHO.
https://www.bilthamber.com/corrosion-prote...s/dynax-uc John
GAP iiD BT-Sold
Post #555806 29th May 2020 5:15pm
