Home > Technical (L322) > Auxillary belt and Pulley replacement - MY12 TDV8 |
Plato69 Member Since: 14 Apr 2016 Location: Felcourt Posts: 7 |
Hi
14th Feb 2019 5:35pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4308 |
Same here. Squeaks when cold. Being done in 2 weeks by local garage. Can’t be doing it myself. Easier to do on my ‘93 Classic which I can handle
14th Feb 2019 7:58pm |
14th Feb 2019 8:00pm |
Thanks, DrRob & Philip, had an on & off squeak last 6 months + a rattle, looking to replace 2 belts and 5 pulleys!
14th Feb 2019 8:14pm |
philip600 Member Since: 04 Feb 2018 Location: North East Posts: 36 |
Hi, that's the 7 parts they've used on mine so you should have all you need other than antifreeze. I think it is easy to break the plastic tee piece coolant pipe on the top hose so be careful with that & good luck. Weather forecast for the weekend is good |
15th Feb 2019 8:19pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8658 |
Be aware the tensioner is pretty easy so is the nearby idler....
16th Feb 2019 8:21am |
Quick update...Parts have just arrived, didn’t make it for the weekend (couple of working days to get the LR parts in) So just spent time making some access. Also cleaning the throttle body, shamefully full of gunk.
19th Feb 2019 12:01pm |
There is a bit of space from the top where it looks like I can get access from the top to fit 3 of the pulley’s Just need a bit of daylight to start. The 9-5 day job not helping!
19th Feb 2019 12:03pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
it is transmission cooler, take those two bolts out and drop culer down ( do not disconnect pipes). 2012 TDV8 Black Edition
19th Feb 2019 3:06pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3778 |
19th Feb 2019 3:42pm |
Yep as above G.box cooler. Don’t take the hoses off, but it should be poss to unbolt and push to one side👍🏻 There is nothing that can't be fixed with a hammer😜😜
19th Feb 2019 5:43pm |
Thanks Nimo & Northernmonkey, oil cooler unbolted last night, bit more room for knuckles now!!
20th Feb 2019 11:15am |
20th Feb 2019 11:29am |
Plato69, I did same thing 2~3 months ago and it is very fiddly job, I am not very good on posting PDF files so if You ask Baltic Blue (Mike) to post PDF for cooling fan removal it will greatly help You to do the job. if You are doing it on a driveway You may consider some sort of ramps, I use this home made.
21st Feb 2019 9:20am |
