Home > Technical (L322) > Auxillary belt and Pulley replacement - MY12 TDV8
Page 1 of 3 123>
Plato69
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
Hi
With the recent rain facilitating, my auxiliary belt has come off, MY12 TDV8 and with the 80k+ on the clock was taking a view while going to the trouble of replacing the belts (Fan, cowling, under trays, poss aircon pipes +++) I might as well look at changing the numerous pulleys.
Does this sound sensible & driveway do-able?
Post #505130 14th Feb 2019 6:35pm
philip600
I've just had mine replaced by an independent specialist. Mine was making a squeaking noise when started from cold. Initially I was just thinking of replacing the tensioner but I was advised that it would make sense to replace the belt & all pulleys at the same time. I understand there is quite a lot to strip off so seemed sensible given I'm planning on keeping her. I think he charged 3 or 4 hours labour & I understand it is time consuming rather than difficult so should be doable on the drive. Mines just turned 86k miles. Good luck.
Post #505145 14th Feb 2019 8:19pm
DrRob
Same here. Squeaks when cold. Being done in 2 weeks by local garage. Can’t be Censored doing it myself. Easier to do on my ‘93 Classic which I can handle Thumbs Up
PS Nice diagram and you get forum discount https://www.advancedfactors.co.uk/auxiliar...1791-c.asp Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #505149 14th Feb 2019 8:58pm
DrRob
https://www.fullfatrr.com/forum/topic48934...=tensioner Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #505151 14th Feb 2019 9:00pm
Plato69
Thanks, DrRob & Philip, had an on & off squeak last 6 months + a rattle, looking to replace 2 belts and 5 pulleys!
LR024791 - Fan Pulley
LR025083 - 80mm idler
LR022953 - 65mm Idler
LR022809 - Tensioner Pulley
LR025988 - Pulley
LR022803 - Belt
LR022804 - Belt
All ordered for the weekend £311 all in,
So apart from the usual bag of spanners, before I roll my sleeves & up is there anything you think I may have missed or should replace while the fan etc are out the way? (apart from a new set of knuckles)
Post #505155 14th Feb 2019 9:14pm
philip600
Hi, that's the 7 parts they've used on mine so you should have all you need other than antifreeze. I think it is easy to break the plastic tee piece coolant pipe on the top hose so be careful with that & good luck. Weather forecast for the weekend is good Smile
Post #505287 15th Feb 2019 9:19pm
Be aware the tensioner is pretty easy so is the nearby idler....
Getting the belt off and getting to the other pulleys 🤷‍♂️ Not so much..... Whistle There is nothing that can't be fixed with a hammer😜😜
Post #505324 16th Feb 2019 9:21am
Plato69
Quick update...Parts have just arrived, didn’t make it for the weekend (couple of working days to get the LR parts in) So just spent time making some access. Also cleaning the throttle body, shamefully full of gunk.
Post #505645 19th Feb 2019 1:01pm
Plato69
There is a bit of space from the top where it looks like I can get access from the top to fit 3 of the pulley’s Just need a bit of daylight to start. The 9-5 day job not helping!
Access from below looking a bit more limited at the moment, does anyone know what this is? Thought maybe oil cooler but not really ribbed enough. I do have the Webasto heater but no idea if this is part of it either.
Hopefully should be able to drop a couple of bolts either side and support suspended but leave connected to give a bit of room, just not keen to undo and have another system to try and refill.
Post #505646 19th Feb 2019 1:03pm
nino_nino
it is transmission cooler, take those two bolts out and drop culer down ( do not disconnect pipes). 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #505668 19th Feb 2019 4:06pm
Baltic Blue
Sorry, I was trying to add a picture from the WM. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #505673 19th Feb 2019 4:42pm
Yep as above G.box cooler. Don’t take the hoses off, but it should be poss to unbolt and push to one side👍🏻 There is nothing that can't be fixed with a hammer😜😜
Post #505697 19th Feb 2019 6:43pm
Plato69
Thanks Nimo & Northernmonkey, oil cooler unbolted last night, bit more room for knuckles now!!
Now to the fan shroud later, & the left hand side pulleys. Don't suppose anyone has anything about the fan & shroud removal. Looks to have a lot of bolts along all sides & a couple of electrical connectors, hoping just a case of undoing these these and easing it up & out with the fan. Confused
Post #505791 20th Feb 2019 12:15pm
Baltic Blue
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #505792 20th Feb 2019 12:29pm
nino_nino
Plato69, I did same thing 2~3 months ago and it is very fiddly job, I am not very good on posting PDF files so if You ask Baltic Blue (Mike) to post PDF for cooling fan removal it will greatly help You to do the job. if You are doing it on a driveway You may consider some sort of ramps, I use this home made.
2000 Disco. TD5
1975 series III
Post #505883 21st Feb 2019 10:20am
Page 1 of 3 123>
