Home > Technical (L322) > Auxillary belt and Pulley replacement - MY12 TDV8
Page 2 of 3 <123>
Baltic Blue
Sorry Plato but I am on holiday at the moment in Tenerife and the Internet is slower than 3rd Class Post, so struggling to post anything.
Mike. Big Cry Thumbs Up G reg 2.5VM Vogue Portofino red 1991- 1999
Post #505886 21st Feb 2019 9:30am
nino_nino
Plato, next best thing is to signe to Topix for few hours and download from the site.
I also found this little ratchet a great help in those tight places
Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #505889 21st Feb 2019 9:58am
http://www.fullfatrr.com/gallery/albums/us...20fan..pdf
Post #505890 21st Feb 2019 10:13am
Baltic Blue
Nino,
That looks a handy little ratchet device.
I have not seen one like that before.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #505896 21st Feb 2019 11:18am
Baltic Blue
Stan,
That is a very clever way of posting a PDF.
Is it restricted to Moderator level or can I have a lesson please.
Mike 😎😎 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #505897 21st Feb 2019 11:39am
Just go into your gallery, you can post a pdf file in there, then grab the url/link for your forum post .
Post #505898 21st Feb 2019 11:51am
Baltic Blue
Thanks Joe, I will give it a try when I return home next week to the joys of my mega fast internet connection rather than this 3G wet string link Rolling with laughter
Post #505900 21st Feb 2019 12:13pm
what tim says mike..load the pdf as a pic the old way and copy/paste the link..
Post #505910 21st Feb 2019 3:16pm
Baltic Blue
I have sent you an apology in a PM. Bow down Bow down
Post #505911 21st Feb 2019 3:25pm
Plato69
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
Many thanks guys for your advice hope the hols went well Mike. Stan Bow down those notes were invaluable, many thanks would have missed a couple of bolts (the one inside the fan cowling and lower o/s one in from corner)
I also added a couple of steps Shocked I removed both air filter boxes and some kind of air pipe underneath by the bolt I missed.
Don’t be fooled by the use of gaffer tape, or the good lady’s gardening glove this is a professional job. Whistle Whistle
Access was a tight, defo Xmas list for the ratchet tool nino-nino & taken onboard the use of a set of ramps.
Post #506244 24th Feb 2019 7:53pm
Plato69
Thought I could shortcut the bespoke fan pulley spanner with a well-placed breaker bar or pry bar but to no avail. Found out the hard way was being too smart for my own good, So have succumbed to its purchase & will look into knuckle replacement on the NHS!!
That’s all the RHS tensioner & pulleys done, just the fan to loosen off and will give me the space to fit the remaining 2 left hand pulleys.
Looking at the state of the old tensioner the spring casing is badly cracked so was probably independently planning its own spectacular war out.
Will update further once the fan pulley tool arrives and daylight permits, but probably next weekend, & the big put back together Thumbs Up
Post #506245 24th Feb 2019 7:55pm
nino_nino
I made my own holding tool and use crescent wrench to undo the bolt, it is LH thread
2000 Disco. TD5
1975 series III
Post #506281 25th Feb 2019 9:40am
Baltic Blue
Plato,
Good luck putting it all back together again.
Job well done 👍
Thanks for sharing.
Post #506293 25th Feb 2019 11:11am
Sonearly
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
Idler Pulley LR025988
A rubber seal comes with this pulley , anyone know where this should be please. Pic posted
Post #572633 12th Nov 2020 11:45pm
Jayk69
Great post going to wait for warmer weather to do mine Smile. where do you get the special tool from? anyone have a part no? 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #572643 13th Nov 2020 8:24am
Page 2 of 3 <123>
