![]() | Home > Technical (L322) > Auxillary belt and Pulley replacement - MY12 TDV8 |
Plato69 Member Since: 14 Apr 2016 Location: Felcourt Posts: 7 ![]() ![]() ![]() |
Hi
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4325 ![]() ![]() ![]() |
Same here. Squeaks when cold. Being done in 2 weeks by local garage. Can’t be |
Thanks, DrRob & Philip, had an on & off squeak last 6 months + a rattle, looking to replace 2 belts and 5 pulleys!
philip600 Member Since: 04 Feb 2018 Location: North East Posts: 36 ![]() ![]() |
Hi, that's the 7 parts they've used on mine so you should have all you need other than antifreeze. I think it is easy to break the plastic tee piece coolant pipe on the top hose so be careful with that & good luck. Weather forecast for the weekend is good |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8687 ![]() ![]() ![]() |
Be aware the tensioner is pretty easy so is the nearby idler....
Quick update...Parts have just arrived, didn’t make it for the weekend (couple of working days to get the LR parts in) So just spent time making some access. Also cleaning the throttle body, shamefully full of gunk.
There is a bit of space from the top where it looks like I can get access from the top to fit 3 of the pulley’s Just need a bit of daylight to start. The 9-5 day job not helping!
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
it is transmission cooler, take those two bolts out and drop culer down ( do not disconnect pipes). 2012 TDV8 Black Edition
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Yep as above G.box cooler. Don’t take the hoses off, but it should be poss to unbolt and push to one side👍🏻 There is nothing that can't be fixed with a hammer😜😜
Thanks Nimo & Northernmonkey, oil cooler unbolted last night, bit more room for knuckles now!!
Plato69, I did same thing 2~3 months ago and it is very fiddly job, I am not very good on posting PDF files so if You ask Baltic Blue (Mike) to post PDF for cooling fan removal it will greatly help You to do the job. if You are doing it on a driveway You may consider some sort of ramps, I use this home made.
