Home > Technical (L322) > 2010 Heated/Cooled Seat not working
Page 9 of 27 <123 ... 8910 ... 252627>
GGDR
I think it's worth a punt.
I've actually bought a Mustang unit to replace my whole unit as a bit of an experiment - and 1/3 the price - and the two units are the same except for the connectors. (Land Rover and Ford).
. Cheers, Greg
Post #488639 11th Sep 2018 7:54am
jmhinkle
United States 2010 Range Rover HSE 5.0 V8 Santorini Black
Is that for the seat back or bottom unit? Which Ford part number did you get? I've come up with a few different ones and in pictures none seem to be an exact fit for the pictures of the RR unit.
Post #488641 11th Sep 2018 7:59am
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
The fans and peltiers are the same parts for both seat base and back, its just the plastic ducting that differs.
They are the same parts as the ford ones too (and some other cars), just connectors differ as Greg has said.
The first thing to determine is which fault codes are being logged, as this gives a major steer as to what is at fault. If the fan runs on cooling, even if only briefly, then you know the fan is good. If the seat gets cool you know the peltier is too (else it wouldn't cool the air). If the fan wont run on heating you will have fault codes. If it says overtemp on the back module it is likely the ducting split, or in the case of the base something restricting sufficient air flow. This is a theory as I have no proof of exactly what causes this. Trying to disconnect the unit from the seat base and running so it can blow to free air would probably see it work. We need somebody to try this though who is seeing that fault code Mr. Green
If that is the case the next problem becomes how to address the restricted air flow. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #488670 11th Sep 2018 12:56pm
SLAMG
2007 Range Rover Supercharged 4.2 SC V8 Java Black
hey there, did anyone end up getting info back on the ford parts? Its getting cold up here in Canada and my heated seats no longer work Sad
Post #495960 19th Nov 2018 6:18am
GGDR
I bought the Mustang unit, it's a replacement for the base unit.
Haven't fitted it yet, looks like it will work though.
Connectors are different.
Will find the part number and post soon. Cheers, Greg
Post #495961 19th Nov 2018 7:11am
GGDR
This one:
https://www.ebay.com/itm/OEM-RH-RIGHT-PASS...nordt=true
. Cheers, Greg
Post #495962 19th Nov 2018 7:14am
SLAMG
oh looks close. will you attempt to install it?
Post #496024 20th Nov 2018 4:02am
GGDR
yes it's on my list.
Weather's getting colder here so might go up on the list too!
Need to remove the whole seat though, so it's a little involved.
. Cheers, Greg
Post #496026 20th Nov 2018 7:48am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
It`s a bit of a struggle to do it in place I did mine, a lot of satisfaction on completion and a nice warm bum now. Smile
Post #496030 20th Nov 2018 8:54am
SLAMG
Did you buy the ford part as well?
thanks
Post #496085 20th Nov 2018 3:38pm
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
Well got a bit more testing done today , pass seat works fine , hot and cold , base and back , warms up quite quickly , drivers seat cools fine , put it on heat and shuts down after a few seconds , reset everything and run on heat with just back , I can hear fan running with my ear against seat but very little heat (compared to pass side ) , looks like it might be expensive , seems like base unit is causing the shut down but the seat back is producing very little heat .
Post #496087 20th Nov 2018 4:45pm
Tinman
Hi, Slamg at the time I did not know about the Ford part so replaced with the LR part @£243 I have a small ratchet with a bit that fitted, in the end, to get the cover off against the centre console that the part that is a PITA,
Post #496088 20th Nov 2018 4:59pm
GGDR
SLAMG the ebay link I posted is a Ford unit. For a Mustang I think.
Soooooo much cheaper than the £243 LR unit.
And it's basically the same unit (different connectors)
***Disclaimer: Haven't actually fitted it yet
. Cheers, Greg
Post #496098 20th Nov 2018 6:23pm
GGDR
matthews - your description issame as mine is doing.
Try switching it on full but immediately switch off the base half using the button.
See if your back unit heats up.
My back unit heats up as long as I deactivate the base straight away. Cheers, Greg
Post #496102 20th Nov 2018 6:36pm
matthews
That's what I find , back will heat but not very hot compared to pass seat as long as I turn base off immediately , leave base on and it all shuts down , going to loosen seat and check all connectors today if I get chance .
Post #496164 21st Nov 2018 10:53am
