![]() | Home > Maintenance & Mods (L322) > Battery Replacement 2011 TDV8 4.4 |
Does this help?
SNDa180 Member Since: 07 Mar 2022 Location: Surrey Posts: 3 ![]() ![]() ![]() |
Thanks @jaygee, that does.
I 'think' the box behind contains the big fuses for the starter motor. Just looking at my picture I think I should put an insulator cover on that terminal. 2012 TDV8 Vogue (L322) |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
A = for the BMS
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 194 ![]() ![]() ![]() |
Hi all,
If the Bosch doesn't have a vent hole then it doesn't need a vent tube. 2012 TDV8 Vogue (L322) |
Well I've checked with the supplier who confirmed that they do not require venting and therefore vent tube etc. isn't supplied.
Richard2113 Member Since: 18 Mar 2021 Location: Banbury Posts: 6 ![]() ![]() |
Thank you to the original poster. A really great tutorial which helped me change my battery with no fuss. I have fitted a Bosch AGM to replace the Land Rover badged Varta. Bought from Tayna batteries who I have used before and recommend - good prices and rapid delivery. 2012 Range Rover L322 Westminster TDV8 |
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 113 ![]() ![]() ![]() |
Thanks for all that usefull information. I have had a bit of luck today, I ordered a new Freelander 2 battery the other day for my daughter, and the supplier said they had a supply issue, would I take a similar battery. I said I would see if it would work, I now have a new super deluxe Rangerover battery! |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4310 ![]() ![]() ![]() |
Another video from Sam |
CaifanSC Member Since: 25 Dec 2018 Location: Maryland Posts: 30 ![]() ![]() ![]() |
Welp...I did my first read of this GREAT thread because my Turtle (Green 2012 US-spec Autobiography) almost made me call the tow truck for the first time. It looks like I have a battery issue and I'm going to have to figure out if it's the battery or a drain. Fortunatelly, I was able to half charge the battery using my Ctek charger and get home.
mcspreader Member Since: 28 Jan 2017 Location: cornwall Posts: 57 ![]() ![]() ![]() |
Many thanks for the guide. Greatly simplified the task particularly the bonnet service position tip although I would recommend doing this with two of you as you really don't want to drop the bonnet with the rams detached at only one end. I found I was able to leave the ECU connected and haul it forward out of the way after removing the two screws that secure the loom going across the panel ahead of the ECU.
Well I've been playing with the CCF battery type data for my vehicle, an 11MY TDV8.
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 79 ![]() ![]() ![]() |
I have just changed my 2012 4.4 to an AGM battery, after the clicky starter motor issue. Absolute pain of a job, and without the 5 point torx it was hard to get everything tight, so I will get one of these off ebay and refit.
