![]() | Home > Off Topic > "G4 Black" Land Rover D3 Project |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
Just remember that the D3 and RRS RAI from Land Rover isn't a snorkel................... they don't have any waterproof seals on them like the ones from LR for Defenders or the Safari ones so you still cannot go into water deeper than 500mm, I'm not sure about this but I think in addition to waterproofing the RAI where it penetrates both the inner and outer wing to allow proper deep water wading you will also still need to extend the breathers a fair bit too. I can also recommend a visit to www.wetroads.co.uk if you fancy trying out some of the fords on the Plain. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
Thanks Tim its more to complete the G4 replica (in black) than deep water wading as I don't want soggy carpets |
Due to not wanting LR spots I have had an idea |
Could be a bit vulnerable to broken lenses from gravel/stones and low hanging branches whacking back from the car infront unless you can get an outer 2nd layer of polycarbonate over the recess to give some extra protection 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
"Branches Wacking Back" I'll have you know my Java is spotless dear boy |
In have the Computer assisted four wheel alignment after the earlier coil lift at BlackBoots yesterday:
No it's not, you are trying to get a deep scratch taken out....................... bet that wasn't done offroad! ![]() |
Oh how wrong you are........... |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2050 ![]() ![]() |
Can you get a lamp pod for the bonnet? |
I have now fitted the LR RAI to the G4 Black using no bolts or holes drilled in bodywork.
You carn't get any better if it's 'Its firm to the "pull" ' |
Tong Off Road near Leeds
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
That umpa lumpa on your roof must have been terrified |
