![]() | Home > Maintenance & Mods (L322) > 2010 - > deployable steps fitting. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8747 ![]() ![]() ![]() |
My bad....I stand corrected, they don't go anywhere on mine either. Was bugging me so I disassembled it and.....
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Hi NMJ!
Just noticed the roof connectors are different. But on yours it all works so that can't be it....
Ok well I pushed in every connector again, did a battery reset and the roof switch is now working!
Macca314 Member Since: 12 Feb 2017 Location: Lincolnshire Posts: 23 ![]() ![]() ![]() |
LandRover 90 1985 300 Tdi Auto, Epsom green LandRover D1 Premium 1998 300 Tdi Auto Rioja red LandRover F1 2004 Td4 HSE Auto Giverney green LandRover FFRR Vogue 20114.4L Tdv8 Fuji white |
The picture No 9 is the wrong way around if you look at the large connectors you need to find the silver Terrian response Box behind the fuse box LandRover 90 1985 300 Tdi Auto, Epsom green
Macca do you mean the RH pic from Step no. 9?
Have a look at this mark-up Macca. Yes there are cables for that silver box behind the fuse board, of the two marked, one goes into the box and the other goes into the cable you pull out of the box.
could the AB black version have illumination in the tread plates of the steps? could it be for that?
Don't think that's it - my kit had the "ultimate' instructions book so would have thought I have (you too probably) the AB ultimate steps complete kit, not just the loom.
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Had my steps fitted today and indie could not find anywhere for the two white connectors to go !!! 2015 4.4 AB
scooby1975 Member Since: 06 Aug 2016 Location: Hampshire Posts: 4 ![]() ![]() ![]() |
How hard is it to fit these to a 2003 vogue ?
Clabs Member Since: 08 Mar 2017 Location: Watford, Herts Posts: 125 ![]() ![]() |
Scooby - have a look at this thread:
