![]() | Home > Maintenance & Mods (L322) > 2010 - > deployable steps fitting. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
My bad....I stand corrected, they don't go anywhere on mine either. Was bugging me so I disassembled it and.....
Is it just the button which doesnt do anything on yours, cos you have to press it and hold it then the light should come on and the steps are locked in whatever config they are in. There is nothing that can't be fixed with a hammer😜😜 FFRR 4.4 SDV8 Autobiography Santorini Black. KIA E-Niro 4+ 2021 Discovery 5 D300 MHEV commercial |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Hi NMJ!
You can see the two white connectors with the yellow wires in the loom on the left. I was working off the instructions for the one one the right which I guess explains why many steps did not make sense. So you and I have the Ultimate Edition version VPLMV0080 (which are the instructions in the Wiki). (If anyone reading this needs the VPLMP0014 version it's here: http://topix.landrover.jlrext.com/topix/service/document/70569 ) Ok so I can stop looking for the loop in the picture. EDIT: These connectors seem redundant unless you have the Ultimate AB. In which case you've probably already got a set. And you're a lucky b**stard!!! Which leaves my roof switch not working. Nothing, even if I press for 5 secs. (at night, the illumination works though) Everything else all good. I might pull the roof console out again and check the connectors, but I'm pretty confident it's all correct. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway Last edited by GGDR on 2nd Sep 2017 6:32pm. Edited 1 time in total |
Just noticed the roof connectors are different. But on yours it all works so that can't be it....
Ok well I pushed in every connector again, did a battery reset and the roof switch is now working!
Macca314 Member Since: 12 Feb 2017 Location: Lincolnshire Posts: 23 ![]() ![]() ![]() |
LandRover 90 1985 300 Tdi Auto, Epsom green LandRover D1 Premium 1998 300 Tdi Auto Rioja red LandRover F1 2004 Td4 HSE Auto Giverney green LandRover FFRR Vogue 20114.4L Tdv8 Fuji white |
The picture No 9 is the wrong way around if you look at the large connectors you need to find the silver Terrian response Box behind the fuse box LandRover 90 1985 300 Tdi Auto, Epsom green
Macca do you mean the RH pic from Step no. 9?
Have a look at this mark-up Macca. Yes there are cables for that silver box behind the fuse board, of the two marked, one goes into the box and the other goes into the cable you pull out of the box.
I think you're right about the RH pic from step 9 being flipped, so that clump of cables must be heading down the pillar (near door hinges). You must be right, because you can see the connectors coming out of the left side but we know they come out of the right side. Well spotted! So I'm plugged onto the silver box (Terrain Resp. Box) - and I checked when I go into terrain modes mud etc they don't deploy. So all ok function-wise. So I can't find any function not working - which is great! But I can't see what those two connectors do / where they connect to... .. Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
could the AB black version have illumination in the tread plates of the steps? could it be for that?
Don't think that's it - my kit had the "ultimate' instructions book so would have thought I have (you too probably) the AB ultimate steps complete kit, not just the loom.
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Had my steps fitted today and indie could not find anywhere for the two white connectors to go !!! 2015 4.4 AB
scooby1975 Member Since: 06 Aug 2016 Location: Hampshire Posts: 4 ![]() ![]() ![]() |
How hard is it to fit these to a 2003 vogue ?
Clabs Member Since: 08 Mar 2017 Location: Watford, Herts Posts: 125 ![]() ![]() |
Scooby - have a look at this thread:
