Home > Maintenance & Mods (L322) > 2010 - > deployable steps fitting.
Page 2 of 6 <123456>
GGDR
Quote:
there is a connector on the 2012 loom which doesn't show on some sets of instructions (2 small white plugs with yellowish wires) these link into the cars loom, it is detailed in the LR fitting instructions in the wiki for the AB, step 10.
So here's where I am struggling:
Step 10 shows the existing wires you need to find (highlighted green). I just can't find them. I've got the glovebox out so visibility relatively good.
Step 9 on the right shows the black arrow inferring there's a clump of wiring (which isn't there) yet:
Step 10 (left side, in green) shows a loop coming down with the connectors at the bottom.
It also doesn't show the clump from Step 9 so very hard to orient where you're supposed to be looking.
Any clues would be very welcome! Thumbs Up
. Cheers, Greg
Post #449757 2nd Sep 2017 11:01am
My bad....I stand corrected, they don't go anywhere on mine either. Was bugging me so I disassembled it and.....
Is it just the button which doesnt do anything on yours, cos you have to press it and hold it then the light should come on and the steps are locked in whatever config they are in. There is nothing that can't be fixed with a hammer😜😜
Post #449760 2nd Sep 2017 12:47pm
GGDR
Hi NMJ!
Wow - thanks for checking! I noticed the manual I had was different and that there are two kinds of looms.
You can see the two white connectors with the yellow wires in the loom on the left. I was working off the instructions for the one one the right which I guess explains why many steps did not make sense.
So you and I have the Ultimate Edition version VPLMV0080 (which are the instructions in the Wiki).
(If anyone reading this needs the VPLMP0014 version it's here: http://topix.landrover.jlrext.com/topix/service/document/70569 )
Ok so I can stop looking for the loop in the picture.
EDIT: These connectors seem redundant unless you have the Ultimate AB.
In which case you've probably already got a set. And you're a lucky b**stard!!!
Which leaves my roof switch not working. Nothing, even if I press for 5 secs. (at night, the illumination works though) Everything else all good.
I might pull the roof console out again and check the connectors, but I'm pretty confident it's all correct.
. Cheers, Greg
Post #449763 2nd Sep 2017 1:01pm
GGDR
Just noticed the roof connectors are different. But on yours it all works so that can't be it....
. Cheers, Greg
Post #449764 2nd Sep 2017 1:12pm
GGDR
Ok well I pushed in every connector again, did a battery reset and the roof switch is now working!
Cool Cool Cool
Thanks for this excellent wiki NMJ - and for checking the connectors.
Best forum ever!
. Cheers, Greg
Post #449779 2nd Sep 2017 5:29pm
Thumbs Up Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #449790 2nd Sep 2017 7:51pm
Macca314
United Kingdom 2011 Range Rover Vogue TDV8 Fuji White
hi i fitted mine a few weeks back.. i found this picture is the wrong way around. the connector it refers to is for the terrain response programe box that is the silver box behind the fuse box the white plugs your looking at further down in your pictures are for adaptive headlight control module
Did you steps come with a little handbook
when TR is selected or Low Range they will not deploy.
i can jack mine up no problems using a trolley jack with an adaptor i made for the correct location or even a hard piece of wood
 LandRover 90 1985 300 Tdi Auto, Epsom green
LandRover D1 Premium 1998 300 Tdi Auto Rioja red
LandRover F1 2004 Td4 HSE Auto Giverney green
LandRover FFRR Vogue 20114.4L Tdv8 Fuji white
Post #449817 3rd Sep 2017 9:29am
Macca314
The picture No 9 is the wrong way around if you look at the large connectors you need to find the silver Terrian response Box behind the fuse box LandRover 90 1985 300 Tdi Auto, Epsom green
Post #449818 3rd Sep 2017 9:31am
GGDR
Macca do you mean the RH pic from Step no. 9?
. Cheers, Greg
Post #449837 3rd Sep 2017 2:29pm
GGDR
Have a look at this mark-up Macca. Yes there are cables for that silver box behind the fuse board, of the two marked, one goes into the box and the other goes into the cable you pull out of the box.
I think you're right about the RH pic from step 9 being flipped, so that clump of cables must be heading down the pillar (near door hinges). You must be right, because you can see the connectors coming out of the left side but we know they come out of the right side. Well spotted!
So I'm plugged onto the silver box (Terrain Resp. Box) - and I checked when I go into terrain modes mud etc they don't deploy. So all ok function-wise.
So I can't find any function not working - which is great!
But I can't see what those two connectors do / where they connect to...
.. Cheers, Greg
Post #449838 3rd Sep 2017 2:37pm
could the AB black version have illumination in the tread plates of the steps? could it be for that?
edit: nope, they don't seem to be, however they do have the illuminated cill plates on the inner cill so might be for that as the door opening and lighting wiring is diverted through the step control module. There is nothing that can't be fixed with a hammer😜😜
Post #449846 3rd Sep 2017 5:05pm
GGDR
Don't think that's it - my kit had the "ultimate' instructions book so would have thought I have (you too probably) the AB ultimate steps complete kit, not just the loom.
The mystery continues...
. Cheers, Greg
Post #449852 3rd Sep 2017 5:38pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Had my steps fitted today and indie could not find anywhere for the two white connectors to go !!! 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #458882 28th Nov 2017 8:39pm
scooby1975
United Kingdom 2004 Range Rover Vogue SE 4.4 V8 Barolo Black
How hard is it to fit these to a 2003 vogue ?
Baz
Post #459210 1st Dec 2017 6:33pm
Clabs
Scooby - have a look at this thread:
http://www.fullfatrr.com/forum/post440040.html#440040
I am not sure if Matt ever overcame the problem with the steps deploying properly with when you open the doors but you will also run into problems fitting the steps because the air tank on the earlier cars gets in the way of the mounting holes.
Post #459217 1st Dec 2017 7:11pm
