![]() | Home > Maintenance & Mods (L322) > 2010 - > deployable steps fitting. |
scooby1975 Member Since: 06 Aug 2016 Location: Hampshire Posts: 4 ![]() ![]() ![]() |
Cheers man, I’ll check it out. 👍 |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
Just fitted mine to a 11.5 model year. NMJ's write up was invaluable thanks! |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
Hi Macca,
Fatfred Member Since: 15 Dec 2017 Location: essex Posts: 55 ![]() ![]() ![]() |
i tried for 2 hours searching for the mystery connectors, in the end i gave up, the steps work perfectly without it FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012 |
Thanks for that. Perhaps I'll stop worrying about it too much then - I'm just trying to get my confidence level up before I start the job - I'm a bit nervous about getting stuck with the car in pieces (and the steps haven't even arrived yet!).
mirras Member Since: 25 Mar 2018 Location: Prestwick Posts: 14 ![]() ![]() ![]() |
Received and fitted the kit yesterday and this write-up made things so much easier, thank you. Tapping out the M8 holes was a must, couldn't get the bolts started without it.
There wasn't enough room to get the ratchet spanner over the end of the two offside rear bolts so it was open ended all the way... boring but doable |
I've still got to find a slot to start doing mine! 2010 4.4 TDV8 Vogue SE |
Been back out this morning and switch still not doing anything at all. Took it apart and tested it with a continuity tester and it's working fine. Must be the wiring or something else not quite right. I couldn't work out how to do the "set ignition to II and hold for 5 seconds bit" as it has a button start so I just pressed the start button without pressing the brake and held the step button in for a while. The steps operate as they should with the key and with doors opening and closing so I'm not too fussed about the button. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
oh really, I got the ratchet ring over those. that air tank is tight close huh?
Something I noticed in a thread on the IID tool is that there is apparently an option in the ccf for deployable side steps...?
Clabs Member Since: 08 Mar 2017 Location: Watford, Herts Posts: 125 ![]() ![]() |
Kooky
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1209 ![]() ![]() ![]() |
Hi, Mirras
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
I turn on ignition , open door , then press and hold step button and steps then stay out enabling them to be washed. 2015 4.4 AB
