![]() | Home > Off Topic > Slow computer fix? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35615 ![]() ![]() |
the only proper clean would be to start from scratch..I agree it's takes a long time but in the end it's worth it..
Defragged, registry cleaned and defragged, and every time I turn it on it gets slower |
philbathurst Member Since: 28 Apr 2013 Location: Iver Posts: 138 ![]() ![]() ![]() |
have you tried a restore point - restore back to a time when it wasn't slow ? and if its a PC hoover the dust out of the insides various other LR's this one is still the best |
What worked for me was replacing the C Drive with a SSID disc and running the operating system from the SSID ultra fast immediate response to everything.
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 ![]() ![]() ![]() |
A good clean up/hoover would be useful on both desktop or laptop.
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2290 ![]() ![]() ![]() |
saw an add yesterday from a usb tool called xtra pc. It seems to speed up the computer.
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
One other thing to check is if there is high utilisation of resources by an svchost process, it could be a virus. So worth running an AV scan. SDV8 AB MY 2019
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 ![]() ![]() ![]() |
how many icons have you got in your task bar at the bottom ,many programs install themselves and run continuously even if you rarely use it. Its ages since I used a windows based computer but here is a handy how to which can speed up your system I always used to uncheck any programs that i knew and that weren't used that often
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1261 ![]() ![]() ![]() |
I use a couple of applications, one is called CCleaner (crap Cleaner!) from Piriform ( http://www.piriform.com/ccleaner ) its free but works well.
You never really speed up an old mechanical hard drive... £70 SSiD is the answer. |
Replace your hard drive with an SSD. Add more memory. those are the 2 things which make the most difference.
Yup 16GB RAM & Ultra Fast SSD BANG! worked for me on 8 year old HP Pavillion Desktop and I did it myself in under an hour and I am no PC expert.... |
