Home > Off Topic > Slow computer fix?
Page 1 of 6 123456>
miggit
Slow computer fix?
Big Cry My puter is slow Big Cry
Banging Head It's driving me nuts Banging Head
Has anyone discovered a clean up program that actually works? Rolling Eyes
Otherwise I'm in to a massive headache of a rebuild, and reloading everthing.. reckon that will be a 3-4 days solid loading Sad Plus some of the programs that I have were downloads and I haven't the foggiest how to save them, so I'll needing to shell out again...
Big Cry just when the ffrr when in to self harm mode.. so far DSP/Radio, Battery, and I'm sporting a cracked windscreen thanks to some Censored driving in the central reservation Evil or Very Mad Yesterday I couldn't spell Engineer... Today I are one!
Post #409241 14th Oct 2016 7:59am
the only proper clean would be to start from scratch..I agree it's takes a long time but in the end it's worth it..
a defrag can help a bit Paul.. ... - .- -.
Post #409243 14th Oct 2016 8:02am
miggit
Defragged, registry cleaned and defragged, and every time I turn it on it gets slower Big Cry Yesterday I couldn't spell Engineer... Today I are one!
Post #409248 14th Oct 2016 8:06am
Andy B
Hi Paul, worth checking both CPU and memory utilisation via Task Manager to see if any particular process or App is hogging resources. Also worth doing a Disc Check in case you have some bad sectors (used to be CHKDSK/F in old DOS days).
Cheers,
Andy SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #409254 14th Oct 2016 8:53am
philbathurst
United Kingdom 2016 Range Rover Vogue SE TDV6 Montalcino Red
have you tried a restore point - restore back to a time when it wasn't slow ? and if its a PC hoover the dust out of the insides various other LR's this one is still the best
Post #409257 14th Oct 2016 9:29am
What worked for me was replacing the C Drive with a SSID disc and running the operating system from the SSID ultra fast immediate response to everything.
Old or little use files can be stored on the non SSID disc/s but if you get a good size SSID disk (500GB Minimum) then everything is lightening fast. Thumbs Up
PS: Windows7 is the only OS I would use.
Last edited by Gazellio @ Prestige Cars on 14th Oct 2016 9:39am. Edited 1 time in total
Post #409258 14th Oct 2016 9:36am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
A good clean up/hoover would be useful on both desktop or laptop.
The other suggestion to look in task manager to see what's hogging resource. I had a problem on a lappy recently due to something called svchost which was using nearly 50% of the cpu. Google suggests a number of solutions but nothing really worked and I ended up dumping the lappy for a new on. Did try upgrading from Vista to Win7 but to no avail. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #409259 14th Oct 2016 9:37am
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
saw an add yesterday from a usb tool called xtra pc. It seems to speed up the computer.
Seems to work with linux as a bypass
https://www.xtra-pc.com/
Post #409260 14th Oct 2016 9:46am
miggit
Shocked That just look a little too good to be true Whistle Yesterday I couldn't spell Engineer... Today I are one!
Post #409263 14th Oct 2016 10:11am
Andy B
One other thing to check is if there is high utilisation of resources by an svchost process, it could be a virus. So worth running an AV scan. SDV8 AB MY 2019
Post #409264 14th Oct 2016 10:13am
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
how many icons have you got in your task bar at the bottom ,many programs install themselves and run continuously even if you rarely use it. Its ages since I used a windows based computer but here is a handy how to which can speed up your system I always used to uncheck any programs that i knew and that weren't used that often
http://www.howtogeek.com/74523/how-to-disa...n-windows/ L322 2008 vogue
R53 Cooper S Works tuned beyond the works SOLD
R33 Nissan Skyline in rebuild 400bhp atw
Post #409266 14th Oct 2016 10:17am
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
I use a couple of applications, one is called CCleaner (crap Cleaner!) from Piriform ( http://www.piriform.com/ccleaner ) its free but works well.
The other one I use is Glary Utilities, I bought a license for this one as you can do more than with the free version. http://www.glarysoft.com/
For AV software I use the Microsoft Essentials as it doesnt hog resources and works, I used to use Kaspersky but it really slowed down my laptop, and I would never ever user Macaffee or Norton Utilities as they kill the machine!
The tip about removing icons is also a good one! at one point I had icons duplicated 3 times, once in the Start menu, another on the desktop and a third one on the bottom taskbar, I now use the taskbar for common used ones (Chrome or Firefox), and outlook, and use the start menu for most programs, and the desktop for photography applications (Photoshop, Bridge, Picasa)
Post #409268 14th Oct 2016 10:36am
You never really speed up an old mechanical hard drive... �70 SSiD is the answer.Whistle
Post #409269 14th Oct 2016 10:38am
mzplcg
Replace your hard drive with an SSD. Add more memory. those are the 2 things which make the most difference.
SSD you can buy as a kit which means you get a USB caddy and a decent USB cable with transfer software. Mine was done in about an hour.
Then look at what you have in the STARTUP section of the system config. START-RUN-type SYSCONFIG and hit enter. Check the boot section and the startup section in the main. Disable stuff you don't use. Initially I would do a diagnostic startup and time the thing. If it's similar to a normal boot up then disabling stuff isn't going to gain much.
Un-install old or unused programs. Clean up the registry. Disable the indexing service if it's running - you don't want this with an SSD anyway.
If it's still slow after that then buy a new PC bud. Thumbs Up
Post #409270 14th Oct 2016 10:41am
Yup 16GB RAM & Ultra Fast SSD BANG! worked for me on 8 year old HP Pavillion Desktop and I did it myself in under an hour and I am no PC expert....
Post #409271 14th Oct 2016 10:45am
Page 1 of 6 123456>
