![]() | Home > Off Topic > Slow computer fix? |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 833 ![]() ![]() ![]() |
I use Microsofts free AV and it serves me well. They update it regularly and it doesn't diminish computer performance, give it a go just because it's free doesn't mean it's rubbish.
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1261 ![]() ![]() ![]() |
I have been using Microsoft Essentials for around a year now and had no problems with it. We did have some AV program installed by a local computer shop, but the price started to go up and it started to get more pop-ups to buy additional stuff, so I binned it and installed Microsoft Essentials, seems to be working fine.
Worth noting that Microsoft got their AV technology from the acquisition of Antigen which was extremely well respected in the IT industry. |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1664 ![]() ![]() ![]() |
ahem... do I have to mention the M word again? |
Yeah, buy a Mac and all your troubles will cost 5 times as much |
The cheapest and arguably one of the best and easiest upgrades you can carry out on an oldish PC is to double or possibly quadruple the RAM.
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
If you have installed an AV, make sure MS Defender is turned of - otherwise they will compete/bottleneck resources.
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
Whilst I agree that more RAM, install SSD, Windows update etc is all good, the OP needs to provide more info on the PC he is talking about if he wants help. Is it a Laptop or a Desktop, what processor does it have, RAM size, Hard Drive type (IDE, SATA)? You need to get to the root cause of the problem before throwing money at the solution. It could be some 'bloatware' is sapping resources or the AV scanning is slowing things down as mentioned in a previous post. Installing an SSD or extra RAM will not solve your problems if you have (unknown) application processes sapping your compute power. Run Task manager as previously advised and by all means send me a PM if you need some help.
More ram |
If it's a 32bit processor then adding more RAM won't help. The 32bit CPU will only run 32bit Windows and thus it can only address (just under) 4GB of memory
Ah, good old Vista |
Adding more than 4GB of RAM to a 32 bit system is a complete waste of money. It can't use it.
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 ![]() ![]() ![]() |
Is it true that they know what they're going to say, but can't stop themselves ![]() 2005 Merc SL350 2005 Disco HSE 2.7 oil burner |
