Home > Off Topic > Slow computer fix?
Page 2 of 6 <123456>
JPHC
Spot on Gaz...Mechanical disk will nearly always be the bottle neck...So swap to SSD and ram upgrade make an old dog run fast! Thumbs Up
What i always suggest to my clients Jordan
'56 SC 4.2 β€˜21-Current
'56 SC 4.2 β€˜16-β€˜18
Post #409274 14th Oct 2016 10:59am
Yes an another bonus is it not only lightening fast but silent too - no more noisy chattering hard disk looking for fragments of a long lost file.... Thumbs Up
Post #409280 14th Oct 2016 12:16pm
RR2008HSE
I've used CCleaner before. Recommended if you have a lot of clutter.
Also, check your startup options. Many programmes "pre-load" and that takes time and resources. MOST (not all) don't need to do this.
Also, the SSD. My laptop got slower and slower. It turned out the (original) HD was failing. Fortunately, I had backed everything up. With a new SSD the improvement is HUGE. I remember needing an address in an email as I was running out the door. Start laptop (Win10), open Outlook, get info, shut down - all about 45 sec total. I hadn't realized, but in a modern computer, a 'regular' HD is, by far, the limiting step when it comes to speed.
(Of course, putting in a new HD, means reinstalling everything. As CTC mentioned, SSD are more expensive than a reg HD of the same size. If cost is an issue, use a smaller SSD only for programmes and the OS. Your files can sit on the reg HD. Loading Windows or Photoshop from and SSD will be hugely faster. Accessing a 100kb Word document is going to be about the same from any HD.
Post #410431 23rd Oct 2016 8:19pm
+1 for the solid state drive as your boot drive. My MacBook runs on a solid state drive and it is lightening fast even though it is a couple of years old and 3/4 full of tat. The iMac runs on a standard hd and is much slower even though it is running 24gb of ram.
Adding the SS drive as your main drive should be fairly easy, but don't ask me how as I dont do windows any more.....
I'm sure that there is a programme which can clone your drive to a new drive running in parallel, you should hen just need to tell the bios which drive to boot from. (I think)
Or just use x copy c: d: (or whatever the new drive is called) from the command prompt. This should copy all files from one drive to the new one. (Trying to remember windows stuff, haven't had a Pc for about 5 years) There is nothing that can't be fixed with a hammer😜😜
Post #410571 24th Oct 2016 8:15pm
miggit
Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #410574 24th Oct 2016 9:08pm
The biggest advantage of SSD over spinning rust is that it takes knocks and bumps much better.
For example when usingnit on a train or in a car on the move the spinning rust drive will stop spinning and retract the heads when it detects the slightest bump and thus slow speeds down even more to avoid damage where as ssd's don't.
Also for most 2.5" laptops and such the drive is made from glass platters. A drop or knock can shatter these and then it's good hey hard drive that no data recovery bar specialist gov services can get anything from! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #410864 27th Oct 2016 7:30am
miggit
Shocked On a train, in the car... I don't think my extension lead is long enough, or the car big enough to get the desk in Shocked
We are talking desk top PC here.... not something you can throw in a bag and sling across your shoulder.... well you could, but you'd probably brake something.... Whistle your shoulder for starters Laughing
Just need to workout how to save the emails without printing them all, and then a rebuild will be on the cards..... Yesterday I couldn't spell Engineer... Today I are one!
Post #410873 27th Oct 2016 9:55am
mzplcg
Miggit, what email program?
Outlook can be exported to a PST file - them re-imported.
Other email clients tend to use files, you just need to copy them.
BTW, I have a few 120GB SSD's (used) here if that's large enough for you.
Post #410876 27th Oct 2016 10:01am
miggit
Rolling Eyes you lost me at hello Embarassed
I'm on Vista and running outlook express.....
And I fear that 120 GB wont be big enough.. my PC's running a 1 TB at the moment.. and while I have moved all the photos and MP3's on to an external drive, I'm still showing 220 GB used, I haven't got the foggiest what is taking all the space... but I think that Rave and the Mercedes WIS aren't helping Wis is best part of 20 GB Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #410882 27th Oct 2016 10:19am
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
I used an application called WinDirStat ( https://windirstat.net/index.html ) that scans your disks and gives you a coloured graphical representation of how the disk space is being used up.
Post #410883 27th Oct 2016 10:27am
miggit
Whistle That would be brown for mine then! Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #410888 27th Oct 2016 10:36am
Easiest way is to take the old drive out and out it into a caddy which is only £5-10 and then when you have installed your new system just pull the lot over in one fell swoop Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #410889 27th Oct 2016 10:41am
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Have a look and see what antivirus program your using, they are responsible for slowing down a lot of computers in my experience.
Kaspersky, Mcafee and Norton are the usual suspects, if you are running an antivirus program, and you should be, disable it and see if that improves the situation. If it does, try Microsofts free antivirus as that doesn't slow things down, if it doesn't then start looking at defragging your hard drive and use C Cleaner to clear out all of the useless stuff that Windows likes to hang on to for whatever reason. Make sure you run both the Windows and registry cleaner and this will take out any redundant software and registry entries. As far as registry entries are concerned, most of the redundant entries get in the way of legitimate entries and slow them down, so it's like going to Edinburgh to get to London from Leeds, hence the slowing down.. ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #410897 27th Oct 2016 11:09am
miggit
Rolling Eyes You might be on to something there... I've been running PCillin since time and I have had it crash a few times recently.... it seams that every time they come out with the new improved version, and stop supporting the old one, it all rather goes down hill Sad
I'll look in to Mircosoft antivirus, Rolling Eyes especially if it's free Wink
Although I have been well served by Trend over the years, with no incidents I have noticed that the price has been creeping up every year and the PC appears to be getting slower Rolling Eyes Yesterday I couldn't spell Engineer... Today I are one!
Post #410905 27th Oct 2016 11:42am
miggit
Shocked The plot thickens Rolling Eyes
Just tried without Trend... I reckon that could be the problem, the computer was way faster with it off Sad
What to do now Rolling Eyes There's no way I want to run without... might reloading Trend, having done a full uninstall help? I'm a bit miffed that the program that I'm paying a small ransom for to protect my computer is slowing it down so much that the computer is almost unusable Evil or Very Mad Yesterday I couldn't spell Engineer... Today I are one!
Post #410910 27th Oct 2016 12:06pm
