![]() | Home > Maintenance & Mods (L322) > Drivers Door Handle |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
It was -8 here last night and no problems with frozen locks for me |
-11 last night where I was north of Spean Bridge. Door locks all worked fine and no misfiring when I started the RR today |
Mine is away as bad as before ................... Lube stuff worked for two days ............ |
This wasn't you trying to get in the car was it Mick? ![]() ![]() |
Did you have to break it free ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
elpeede, you got it spot on mate..the water does indeed get in via the window trim, runs down a 'runner' straight onto the lock mechanism.. the only way to sort this ,is to remove the lock assembly completely and dry it out and lubricate inside the lock and the cables . ... - .- -.
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
SO far ok with only one moment where the door lock failed to come up.. different cable!
Two days back i sprayed WD40 White Grease inside the lock with the tube/straw attachment so far so good .... |
it appears the correct answer could be to rub a sheep over the latch mechanisim or buy some sheep water proofing in a pot http://www.flints.co.uk/acatalog/Marine_Lanoguard.html |
dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477 ![]() ![]() |
My drivers door cable also failed last Friday just as I was leaving for work, I've had to live with it for a week as I've been away in Warcop and Catterick - muchos bummer!!!
DougBLC Member Since: 23 Jul 2016 Location: Barton-Le-Clay Posts: 6 ![]() ![]() ![]() |
Nearly 5 years since this posting, but looks the most likely link to my problem. 2011 TDv8VSE rear o/s passenger door stopped working suddenly, cant open from outside or inside handles. Remote lock works fine, is this most likely cable snap?
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Just had my 07 TDV8 drivers side go, same thing couldn't open it from the outside, no resistance on the handle.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
great thread this! Had my external door cable go the other day so searched and found this thread: followed it to a tee and got everything off in 35 mins only to find when trying to put the new cable end into the slot that it won't go! so had to take the door locks off (great powerful Uk youtube vid BTW!) to see why not, only to find the old broken end of the wire is firmly and irrevocably seized in the hole! Have tried drilling it out to no avail.
