Home > Maintenance & Mods (L322) > Drivers Door Handle
Page 2 of 5 <12345>
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
joanne wrote:
How do you boys get any work done... youre always changing cables for this cables for that !!
Smile Laughing
Work is merely a means to pay for the sat nav, injectors, turbo and gearbox that I've replaced in the last 12 months... I'm holding out on the suspension compressor mind (though did buy a fault reset tool - fingers crossed for an overhaul kit like the P38 has) . Maybe Santa will bring me some overtime Bow down
Todays household failures... Electric shower and home PC hard drive.
Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #37728 22nd Nov 2010 12:56am
joanne
Will I actually ever need to go to a garage again???? All I could do is ask you guys.....
I have no idea at half the things you qupted, however all I want santa to bring me is a new handbag and maybe just maybe a a new chillow for my pillow I just left mine in uae Sad
Post #37729 22nd Nov 2010 6:25am
I've just spoken to LR this morning regarding the cable. Apparently there are two cables and they cost £7.00-£8.00 each. I was told the most common one for breaking was the lock to exterior handle, but it is my interior handle that is notchy. For the sake of a few pounds and whilst the door is stripped I am going to change both cables.
Post #37759 22nd Nov 2010 9:38am
I now have the two cables at a cost of £16.30 so will fit them today
Post #37766 22nd Nov 2010 10:51am
crikey you dont hang about....... Thumbs Up ... - .- -.
Post #37767 22nd Nov 2010 10:54am
JMC
Hot flushes at night can be such a bitch............ Laughing The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #37799 22nd Nov 2010 12:46pm
The two new cables are fitted, the most difficult part is removing and refitting the door card, it's a pig of a job that requires a little patience so that nothing breaks. The lock mechanism has to be removed from the vehicle to replace the cable that runs from the inner handle, if the cable from the outer handle is broken this can be replaced with the lock in situ.
The bad news was my cables from what I can see look fine, they were not frayed and run in their outers freely, but as I had the new ones there was no point refitting the old ones and they will now be put in the spares box.
When I rebuilt everything I tried opening the door from the inside before fitting the door card and the mechanism was still very notchy, so I dismantled it again and lubricated the lock mechanism which seems to have been what my original problem was. To lubricate the inside of the lock it has to be completely removed from the vehicle, so if anyone is fitting new cables it is worth putting a few drops of oil in the lock before refitting.
Once you have fitted the inner cable and whilst the lock is off the vehicle I suggest you operate the lock by pulling the cable a few times to ensure it is working smoothly, this will save you having to remove it later.
Post #37833 22nd Nov 2010 1:43pm
good review , glad it went ok.. Thumbs Up ... - .- -.
Post #37838 22nd Nov 2010 1:47pm
This is the two cables, the one at the top is the exterior handle to lock cable and the lower cable is the interior handle cable to lock
Part numbers are
LFQZ000041 (exterior to lock) (top cable in picture) £6.99 + VAT
LRO11173 (interior to lock) (bottom cable in picture) £8.25 + VAT
....less any discount you can obtain
Post #37871 22nd Nov 2010 3:08pm
elpeede
Arrived today but way to cold / dark to do it now. Does any one know the card seems to be held with torx screws from the clip I saw. What size? I'm not confident that my socket set will get in to access the screws so I'll get the relevant torx type screwdriver before hand. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Post #39099 24th Nov 2010 6:23pm
There are two different sized Torx heads, I'll have a look later and let you know the sizes
Post #39105 24th Nov 2010 6:48pm
The two sizes you require are T20 & T30 Thumbs Up
Post #39205 24th Nov 2010 10:17pm
elpeede
Thanks dude! Thumbs Up 2010 Disco XS TDV6, 2009 Freelander 2 GS
Post #39462 26th Nov 2010 3:32am
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
-5C this morning and the drivers door wouldn't stay shut (once I had got in), so I locked it with the button ... Then 20 minutes later, after unlocking with the central locking, neither inside nor outside door handle would open the door - is it likely that both cables have gone ?
Post #39467 26th Nov 2010 8:04am
It's sounds like the lock mechanism that has frozen
Post #39471 26th Nov 2010 8:25am
Page 2 of 5 <12345>
