Home > Maintenance & Mods (L322) > Drivers Door Handle |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35435 |
mine was like this today, i thought i'd cured it by spraying silicon lubricant in the locks but apparently not...if you drive the RR it takes about 10/15 minutes to defrost..more spraying me thinks.. ... - .- -. Y. O. L. O. . |
26th Nov 2010 8:29am |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 |
Correct diagnosis - a frozen lock which had defrosted by this evening - big relief !! |
26th Nov 2010 10:53pm |
this frozen door handle in a pain..this morning i had to go to the hospital at 4.30am and the bloody handle was frozen so i had get in through the passenger side..not a good impression for a RR.. ... - .- -.
27th Nov 2010 8:27am |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
yep this was what i experienced. I suspect the manual locking was just enough to jolt it free but then it refreezes. I was sent down the cable path at rr.net or what ever its called. Maybe its just the latch needing some vaseline.. Handle is crotchy so i'll do the cable regardless.
27th Nov 2010 12:45pm |
found and solved the freezing problem...its the mechanism at the back of the door latch which gets frozen..water runs down the inside right onto this mechanism and causes the problem...you need to dry the area with a hairdryer and cover it with silicon lubricant and for extra protection put some grease or similar on it....the proof in the pudding will be tomorrow morning when i test the door... ... - .- -.
28th Nov 2010 2:20pm |
Cheers scarey that happened to me at 1.30am this morning going to pick the daughter up opened door , door would not lock once inside had to drive 3 miles holding a door closed from the inside ......... |
28th Nov 2010 2:26pm |
i was getting in and out via the passenger door and that wasnt easy for an old git like me...
28th Nov 2010 2:28pm |
Tell me about it done that last week .............
28th Nov 2010 2:30pm |
its dead embarrassing seeings its a premium motor vehicle.. ... - .- -.
28th Nov 2010 2:31pm |
My mate gave me this to try so time will tell tomorrow ....... sprayed this in the door lock just now
28th Nov 2010 2:41pm |
Also meant to say that pfege stuff for the door seals work , |
28th Nov 2010 2:44pm |
handy to know re the 'pledge' ...spraying in the door lock wont work mick [tried it ], the lubricant cant get to the back of the lock where the water accumulates ... the only way is by taking the door card off and getting in that way.. ... - .- -.
28th Nov 2010 5:00pm |
The spray somehow worked scary, -7 this morning opened the door fearing it would not lock when i closed it , but the lock worked fine , do for me ........ |
29th Nov 2010 10:30am |
It will only freeze if there is water in there in the first place - and there shouldnt be. |
29th Nov 2010 11:11am |
