Home > Maintenance & Mods (L322) > Drivers Door Handle
Page 4 of 5 <12345>
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
So I guess that the recent slush from deiced windows running immediately down the window edge / runner is refreezing on the cold metal right wher it lands on the latch then Evil or Very Mad
Must get those torx screwies and get it sorted before it becomes a problem. I've been sat at work previously praying it would hurry up and latch so I could lock the car and go in to work.
I think an emergency ratched strap in the boot may be in order ... wrapped around both interior door handles.. better than leaving the doors open.. but less than ideal.
Thing is it's a double edged sword as now it too friggin cold to go and sort it Rolling Eyes
I may try and sneak it in one of the bays at work Whistle 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #40126 29th Nov 2010 10:23pm
It was -8 here last night and no problems with frozen locks for me Thumbs Up
Post #40198 30th Nov 2010 4:46pm
-11 last night where I was north of Spean Bridge. Door locks all worked fine and no misfiring when I started the RR today
Post #40378 1st Dec 2010 3:58pm
Mine is away as bad as before ................... Lube stuff worked for two days ............ Embarassed
Post #40386 1st Dec 2010 4:27pm
This wasn't you trying to get in the car was it Mick? Rolling with laughter Rolling with laughter
Post #40389 1st Dec 2010 4:36pm
Laughing Laughing Laughing Laughing
Post #40390 1st Dec 2010 4:40pm
Did you have to break it free Rolling with laughter Rolling with laughter
Post #40398 1st Dec 2010 5:25pm
elpeede, you got it spot on mate..the water does indeed get in via the window trim, runs down a 'runner' straight onto the lock mechanism.. the only way to sort this ,is to remove the lock assembly completely and dry it out and lubricate inside the lock and the cables . ... - .- -.
Post #40482 2nd Dec 2010 10:09am
elpeede
SO far ok with only one moment where the door lock failed to come up.. different cable!
I've not used de-icer on the door though.. just a scrapper.
Once it thaws out I'll sort the cable I have and lube up the lock mech.. take a peek at the other cable too. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Post #40837 4th Dec 2010 5:40pm
Two days back i sprayed WD40 White Grease inside the lock with the tube/straw attachment so far so good .... Thumbs Up
Post #40838 4th Dec 2010 5:43pm
elpeede
it appears the correct answer could be to rub a sheep over the latch mechanisim or buy some sheep water proofing in a pot http://www.flints.co.uk/acatalog/Marine_Lanoguard.html Thumbs Up 2010 Disco XS TDV6, 2009 Freelander 2 GS
Post #41056 6th Dec 2010 3:16am
dantheman
My drivers door cable also failed last Friday just as I was leaving for work, I've had to live with it for a week as I've been away in Warcop and Catterick - muchos bummer!!!
Bought a replacement cable today from Land Rover (a little over �7) and fitted it on the driveway this afternoon when I got home from work... a little fiddly but on the whole not too bad a job. If anything, the door card was a bit of a b Censored d to refit. Rolling Eyes
Post #69893 24th Jun 2011 11:13pm
DougBLC
United Kingdom 2011 Range Rover Vogue SE TDV8 Zambezi Silver
Rear o/s handle this time...
Nearly 5 years since this posting, but looks the most likely link to my problem. 2011 TDv8VSE rear o/s passenger door stopped working suddenly, cant open from outside or inside handles. Remote lock works fine, is this most likely cable snap?
Also, can the door card be removed when door shut?
Thanks
Doug
Post #399963 10th Aug 2016 4:38pm
TJH1985
Just had my 07 TDV8 drivers side go, same thing couldn't open it from the outside, no resistance on the handle.
Local stealer had one in stock �32!! Was about 45 minute job in the dark including cleaning everything up. We used a gentle hot air gun on the sealant holding down the foam trim and it came off / went back on perfect.
Cheers guys, enabled me to order the part without haveing to strip the door down first!
Post #413598 14th Nov 2016 8:58pm
Dolphinboy
Bloody Nubbin seized in situ!
great thread this! Had my external door cable go the other day so searched and found this thread: followed it to a tee and got everything off in 35 mins only to find when trying to put the new cable end into the slot that it won't go! so had to take the door locks off (great powerful Uk youtube vid BTW!) to see why not, only to find the old broken end of the wire is firmly and irrevocably seized in the hole! Have tried drilling it out to no avail.
Any ideas anyone?
Post #447748 13th Aug 2017 10:29pm
Page 4 of 5 <12345>
