Home > In Car Electronics (L322) > upgrade to DAB+
Page 1 of 8 12345678>
chief64
Norway 2010 Range Rover Autobiography TDV8 Buckingham Blue
upgrade to DAB+
One article about install DAB+ in Freelander,using parts from Jaguar, maybe possible in Range Rover also?http://www.freel2.com/forum/topic25664.html
Post #372875 18th Feb 2016 7:34am
If only , you would have thought that they would have the same M,O,S,T system wouldn't you ?
Ah no Sad 2008 MY Supercharged
Post #372890 18th Feb 2016 9:04am
you should have DAB in yours already chief....there's no benefit in upgrading from DAB to 'DAB+'..... ... - .- -.
Post #372896 18th Feb 2016 9:16am
dhallworth
Having seen that thread on FL2.com when I was doing the Xenon lights on ours it made me think about it.
I've used the IID tool to check that the DAB can be enabled on our cars CCF and am going to order the parts tomorrow.
I asked a similar question about retrofitting it to our SC when we got it but was told it wasn't possible. Shame really as I do love how much clearer DAB is then standard FM.
Post #376065 7th Mar 2016 1:36am
ksskaret
Norway 2010 Range Rover Autobiography TDV8 Santorini Black
Stan, there is a benefit upgrading to DAB+ because most of the transmitting is now done in the DAB+ band width in Norway Sad
I live up in the northern parts of Norway with lousy DAB conditions, should have had DAB+ ( and they will switch off the FM net in 2017)
But I guess for the rest of you there is no benefit WinkSmile Range Rover TdV8 Autobiography MY2010
Defender 110stw Td5 MY2006
Post #379985 29th Mar 2016 8:02pm
comports
Interesting - incidentally (and I'm going to show my age now) but I listen to Absolute 80s in the car on DAB. They recently announced changing to "Absolute 80s New" but the reception is hit and miss for me. It drops out a lot more and cannot connect half the time.
Is this down to a different transmitter or maybe because its DAB+ or something.? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #379998 29th Mar 2016 8:59pm
i think they moved to a different multiplex Ash... ... - .- -.
Post #380003 29th Mar 2016 9:44pm
comports
thanks mate Thumbs Up Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #380005 29th Mar 2016 9:50pm
chief64
upgrade to DAB+
Upgrade done, install new DAB+ unit CPLA-14F720-BM, working good.
Post #428395 19th Feb 2017 6:10pm
nice job, was it a straight swop? ... - .- -.
Post #428420 19th Feb 2017 8:13pm
chief64
Yes it was easy, just to add the antenna amp to the coax,right side and install the DAB unit on left side,conect coax and MOST, and power. And conect the diagnose GAP, and change setting for DAB.
Post #428480 20th Feb 2017 9:19am
Thumbs Up ... - .- -.
Post #428481 20th Feb 2017 9:26am
nino_nino
how do I know if i have DAB ? Embarassed
Post #428484 20th Feb 2017 10:40am
Post #428485 20th Feb 2017 10:51am
nino_nino
Thank You Stan, no, i don't have DAB . I would appreciate if you guys can tel me if i have required wiring for the installation of one in my car.
Thanks,
Post #428513 20th Feb 2017 3:15pm
