![]() | Home > In Car Electronics (L322) > upgrade to DAB+ |
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 ![]() ![]() ![]() |
Interesting. Anybody attempt to use the window aerial for a DAB installation? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35542 ![]() ![]() |
my westie has both FM and DAB radio and uses the same antennas... |
unless you want to splice into the existing antennas then i wouldnt worry to much and just use the ariel supplied with your aftermarket dab receiver.. |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 336 ![]() ![]() ![]() |
Has anybody tried this, and is it a straight swap with CPLA-14F720-BM?
this chap has done it... ... - .- -. Y. O. L. O. . |
Thanks Stan.
Module arrived today (CPLA-14F720-BP) and I've encountered the first problem; the power connector is different.
Just as a heads up to anybody following this thread. I couldn't get this to work.
it could be because yours is a 'BP' and the one that the OP got working is a 'BM'.. ... - .- -.
It could be Stan, but I was led to believe that the last two characters are only the software level, and should've worked in my car.
chief64 Member Since: 14 Oct 2015 Location: AALESUND Posts: 21 ![]() ![]() ![]() |
I have DAB+, and the unit was from a newer Jaguar,there DAB+ was factory installed original.
Chief64
PatrickJamesL Member Since: 24 Aug 2019 Location: Surrey Posts: 1 ![]() ![]() ![]() |
Hi John, did you manage to get the DAB+ module working? Looking to try and do the upgrade next weekend as my favourite station has now become DAB+. |
