![]() | Home > In Car Electronics (L322) > upgrade to DAB+ |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
In our MINI there are so many extra channels. That is DAB+
Jase0851 Member Since: 25 Jul 2021 Location: Uk Posts: 5 ![]() ![]() |
CPLA-14F720-BM was mentioned on a previous post presumably this is the L405 module, think i ll remove mine and see which one is already fitted as i would like DAB+ also |
andyducati Member Since: 01 Sep 2017 Location: Eltham, Victoria Posts: 25 ![]() ![]() ![]() |
Where exactly in the LH cubby does the DAB module sit? Is it behind the DVD Video module (AH42-19A164)? My car is an AUS spec with no DAB from factory. I can't find any power connector or MOST connector, but I think I have the coax connectors floating around the bottom of the LH side. got a White and a beige coax connector
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 150 ![]() ![]() ![]() |
On the first Pic, the DAB it’s left of the Video-Module underneath the black "thing”, behind that steel cage you see on the second pic. |
MartinD Member Since: 20 Oct 2010 Location: Edinburgh Posts: 303 ![]() ![]() ![]() |
Has there been any definitive resolution to this, which modules will definitely work and what's involved?
Well, I've bought one anyway and shall see what happens. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
I have the L405/L494 module.
Would that be the CPLA-14F720-BM?
I believe so.
So, can't buy the plugs for love nor money and the patch loom (from Jag) seems to be unavailable and out of stock everywhere, too! 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Ordered plugs 4 weeks ago... Arrived today!
Faukstad Member Since: 27 Dec 2021 Location: Oppland Posts: 66 ![]() ![]() ![]() |
Did anyone find out how to get this working..? |
I've received all the bits I believe I need; struggling to find the time to get stuck in. This weekend, hopefully. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 87 ![]() ![]() ![]() |
Hey MartinD where did you get the plugs from?
