Home > In Car Electronics (L322) > upgrade to DAB+
Page 6 of 8 <12345678>
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
I ordered the D-JV-2 module from Cameron and installed it today, easy Plu&Play installation and works perfect. Thumbs Up Bow down
Post #546902 12th Mar 2020 12:43pm
Alinton
Ireland 2011 Range Rover Vogue TDV8 Zambezi Silver
Sorry I didn't reply to your questions - glad you got yours installed. I got my module from a place in the UK, but got Cameron's bracket (as I found out about him after ordering the module).
Works great! Swapping in the L405 module definitely does NOT work!
A
Post #548335 26th Mar 2020 2:01pm
bulledk
Denmark 2011 Range Rover Autobiography 4.4 V8 Fuji White
Hi All,
I'am newbie in here...
GAP Team, told me to find answer for my problem in here...
I bought a in2digi module, for retrofitting DAB+ on my RR.
The module is installed with MOST splitter through Phone interface and also the power. My car has TV, so it was "prepared" for DAB antenna amplifier, so that is also fitter and installed to the module.
I changed the "Digital radio receiver" to "HD&DAB with PTY EU / ROW" and also "DAB" through IIDTool but DAB button is not showing on HU.
What am I doing wrong?
Post #567628 21st Sep 2020 5:01pm
Ansi
Did your Fatty have DAB installed and you changed to DAB+?
I had DAB before, therefore after Installing I only had to switch to DAB+ and it was done.
So, sorry, can't help you on this issue.
You may ask Cameron for help?
Post #567630 21st Sep 2020 6:18pm
bulledk
No I did not have DAB before.
What do you mean by "Switch to DAB+"
If you have DAB before, then you shouldn't do anything else than install the module?
Post #567639 21st Sep 2020 7:10pm
bulledk
I figured out what's was "wrong".
I read that many people have changed the CCF option "Digital radio reciever" but that was not the correct line. After talking with Cameron (thank you soo much) the right CCF was "Digital Audio Broadcasting Receiver (DAB) Fitment" from "Not fitted" to "Fitted with digital audio broadcasting."
That option was not listen on my IIDTool. You have to get GAP Team to activate the full list.
So now my Fatty has DAB+ and working great. Only need to find the extender cable from antenna connecter from the amplifier to the in2digi module.
Post #567856 23rd Sep 2020 6:49pm
Gold Ranger
United Kingdom 2010 Range Rover Vogue TDV8 Santorini Black
I’ve already got dab radio in my 2010 vogue and would like to have the dab+ function
So is it a case of seeing which unit I have and get a later one that’s come out of a Jaguar and plug and play or is it a case of messing around with wiring to make one work
Cheers
Post #588338 22nd Mar 2021 1:11am
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
So I installed
CPLA-14F720-BM
over the weekend. Only way I can access DAB is by turning unit off and pressing DAB option with unit off. It then turns on and DAB works.
2011 L322
Anyone else had similar?
Post #599031 28th Jun 2021 8:27pm
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
Got the same problem. Also if traffic info interrupts the broadcast I have to change the volume to get ANY sound, as I do if I'm on DAB, turn the engine off and restart the car; no sound until the volume is changed! Weird.
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #599038 28th Jun 2021 9:20pm
JNC
Is your unit the exact same part no?
Post #599045 28th Jun 2021 10:05pm
RRDunc
No, mine is CPLA-14F720-BP.
Post #599048 28th Jun 2021 10:21pm
JNC
I guess that rules out the difference in software being the issue.
Has anyone managed to get them to work properly?
Post #599101 29th Jun 2021 11:50am
probably an obvious question but have tried a battery reset.. ... - .- -.
Post #599112 29th Jun 2021 12:42pm
RRDunc
I had a new battery fitted since changing the module; would that do it or do I need to short the leads out?
Post #599173 29th Jun 2021 9:23pm
supershuttle
This may be a silly question (nothing new there 😀) but when (if) did JLR make DAB+ standard. I’ve got an early L405 so how would I know ? Geoff
Post #599213 30th Jun 2021 7:45am
