![]() | Home > In Car Electronics (L322) > upgrade to DAB+ |
If only , you would have thought that they would have the same M,O,S,T system wouldn't you ?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35511 ![]() ![]() |
you should have DAB in yours already chief....there's no benefit in upgrading from DAB to 'DAB+'..... ... - .- -.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3154 ![]() ![]() ![]() |
Having seen that thread on FL2.com when I was doing the Xenon lights on ours it made me think about it.
ksskaret Member Since: 27 Oct 2013 Location: Tromsų Posts: 73 ![]() ![]() ![]() |
Stan, there is a benefit upgrading to DAB+ because most of the transmitting is now done in the DAB+ band width in Norway ![]() I live up in the northern parts of Norway with lousy DAB conditions, should have had DAB+ ( and they will switch off the FM net in 2017) But I guess for the rest of you there is no benefit ![]() ![]() Defender 110stw Td5 MY2006 Last edited by ksskaret on 29th Mar 2016 8:53pm. Edited 1 time in total |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1749 ![]() ![]() ![]() |
Interesting - incidentally (and I'm going to show my age now) but I listen to Absolute 80s in the car on DAB. They recently announced changing to "Absolute 80s New" but the reception is hit and miss for me. It drops out a lot more and cannot connect half the time.
i think they moved to a different multiplex Ash... ... - .- -.
thanks mate |
chief64 Member Since: 14 Oct 2015 Location: AALESUND Posts: 21 ![]() ![]() ![]() |
Upgrade done, install new DAB+ unit CPLA-14F720-BM, working good. |
nice job, was it a straight swop? ... - .- -.
Yes it was easy, just to add the antenna amp to the coax,right side and install the DAB unit on left side,conect coax and MOST, and power. And conect the diagnose GAP, and change setting for DAB. |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
how do I know if i have DAB ? |
Thank You Stan, no, i don't have DAB . I would appreciate if you guys can tel me if i have required wiring for the installation of one in my car.
