Home > In Car Electronics (L322) > upgrade to DAB+
Page 7 of 8 <12345678>
Andy
In our MINI there are so many extra channels. That is DAB+
Scrolling through yesterday I found Union Jack Radio, Union Jack Rock and Union Jack Dance. None of these appear in our 2010 VSE. I’d like to enable DAB+ 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #604425 22nd Aug 2021 8:21am
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
I wouldn’t recommend fitting the L405/494 module as listed previous.
Seems to cause a few issues with the infotainment system.
Post #604562 23rd Aug 2021 12:29pm
Jase0851
2012 Range Rover Vogue TDV8 Orkney Grey
CPLA-14F720-BM was mentioned on a previous post presumably this is the L405 module, think i ll remove mine and see which one is already fitted as i would like DAB+ also
Post #604574 23rd Aug 2021 1:40pm
andyducati
Australia 2012 Range Rover Autobiography 5.0 SC V8 Santorini Black
Where exactly in the LH cubby does the DAB module sit? Is it behind the DVD Video module (AH42-19A164)? My car is an AUS spec with no DAB from factory. I can't find any power connector or MOST connector, but I think I have the coax connectors floating around the bottom of the LH side. got a White and a beige coax connector
Ive got the connectors for the green amp thing in the RH side top but no green amp.
The power connector for the DAB is not an issue but how do I get MOST to it if I don't have a connector. is there a form of splitter for the MOST and is it available from LR.
Thanks
Andy
 A Solihull born Pom in Oz
Post #607274 25th Sep 2021 8:04am
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
On the first Pic, the DAB it’s left of the Video-Module underneath the black "thing”, behind that steel cage you see on the second pic.
Post #607752 30th Sep 2021 7:16am
MartinD
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Has there been any definitive resolution to this, which modules will definitely work and what's involved?
Really want to get Dab+ sorted on my 2011 as I'm missing a lot of the stations I'm used to. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
2000 4.0 P38 HSE - 'Green Goblin' - Gone.
Audi..Mini..BMW..
Post #626405 17th Mar 2022 6:10pm
MartinD
Well, I've bought one anyway and shall see what happens. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #626406 17th Mar 2022 6:25pm
JNC
I have the L405/L494 module.
Whilst it works, it has it quirks.
You have to turn off the radio then select DAB to turn the unit on to DAB.
If you receive a call sometimes it doesn't mute the radio, the rest of the time, after the call you need to adjust the volume to start the music again.
I use it around these faults no problem but would prefer a better solution.
Post #626456 18th Mar 2022 7:30pm
MartinD
Would that be the CPLA-14F720-BM?
Was there anything funky required with regards to wiring/splicing and CCF edits or anything? 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #626458 18th Mar 2022 8:15pm
JNC
I believe so.
The power plug is different. You can get a patch loom. I just modified a plug I had to work.
Post #626459 18th Mar 2022 8:17pm
MartinD
So, can't buy the plugs for love nor money and the patch loom (from Jag) seems to be unavailable and out of stock everywhere, too! 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #626873 24th Mar 2022 6:45am
MartinD
Ordered plugs 4 weeks ago... Arrived today!
Flying back home tonight so hopefully get a wee fiddle with it all tomorrow! 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #629428 22nd Apr 2022 5:00pm
Faukstad
Norway 2012 Range Rover Autobiography TDV8 Santorini Black
Did anyone find out how to get this working..?
Post #629842 27th Apr 2022 5:35am
MartinD
I've received all the bits I believe I need; struggling to find the time to get stuck in. This weekend, hopefully. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #629845 27th Apr 2022 6:09am
Rackers
Hey MartinD where did you get the plugs from?
Thanks
Post #631630 14th May 2022 3:02pm
