Home > In Car Electronics (L322) > upgrade to DAB+
Page 3 of 8 <12345678>
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
Interesting. Anybody attempt to use the window aerial for a DAB installation?
Post #491562 9th Oct 2018 11:35am
my westie has both FM and DAB radio and uses the same antennas...
Post #491564 9th Oct 2018 11:40am
S.Hafsmo
And you are certain the later models didn't change the design of the window aerial? Are there any available web-sites where one can find part numbers for certain model years?
It would seem strange that they didn't as the different wave lenghts of the DAB-signal usually requires different antenna properties than the old FM signal.
Post #491567 9th Oct 2018 11:48am
unless you want to splice into the existing antennas then i wouldnt worry to much and just use the ariel supplied with your aftermarket dab receiver..
Post #491577 9th Oct 2018 12:53pm
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Has anybody tried this, and is it a straight swap with CPLA-14F720-BM?
I currently have DAB, but would like DAB+ as one of that stations I'd like to listen to is only broadcast on DAB+
Post #523901 6th Aug 2019 3:32pm
Re: upgrade to DAB+
chief64 wrote:
Upgrade done, install new DAB+ unit CPLA-14F720-BM, working good.
this chap has done it... ... - .- -.
Post #523905 6th Aug 2019 4:19pm
millerj90
Thanks Stan.
I did see and read that, just wondered if anyone else had done it.
Next problem is. Having looked in the RHS electronics bay, I cant actually figure out what unit is what. The workshop manual isn't much help either.
I guess this is going to be a project for a rainy day Smile
Post #523909 6th Aug 2019 4:47pm
millerj90
Module arrived today (CPLA-14F720-BP) and I've encountered the first problem; the power connector is different.
On the old (Focom) module its a two pin connector on the new its a four pin connector!
Anyone have a diagram of the old and new, in the hope that I can rig something up.
Many thanks
Post #524366 10th Aug 2019 12:09pm
millerj90
Just as a heads up to anybody following this thread. I couldn't get this to work.
Got power and all other connections to the unit, even though DAB appeared on the centre screen menu, I was unable to select it..
I also looked through the CCF for any changes that may be required. I tried DAB and DAB (PTY) for EU, neither of which had any effect.
Post #524538 12th Aug 2019 2:26pm
it could be because yours is a 'BP' and the one that the OP got working is a 'BM'.. ... - .- -.
Post #524540 12th Aug 2019 2:39pm
millerj90
It could be Stan, but I was led to believe that the last two characters are only the software level, and should've worked in my car.
Having done even more research, I'm not sure this can be done in a 2012. Chief64's profile shows a 2010 model and cambo@oldjaguar states "There's no factory DAB+ module that's compatible with the audio system in the 2010-2012 L322, the factory modules are only DAB, not DAB+, so they don't work here."
I'll lurk around a bit before returning the unit, in the hope that someone has had some success with this.
As always, thanks for your help and the continued maintenance of a brilliant site.
Post #524541 12th Aug 2019 3:14pm
Thumbs Up ... - .- -.
Post #524542 12th Aug 2019 3:56pm
chief64
Norway 2010 Range Rover Autobiography TDV8 Buckingham Blue
I have DAB+, and the unit was from a newer Jaguar,there DAB+ was factory installed original.
Using the original DAB antenna.
Post #524595 13th Aug 2019 10:08am
millerj90
Chief64
Many thanks for the reply, you've given me the confidence to have another go at this. I have sourced the exact same part number that you used (CPLA-14F720-BM), so will give it another go.
Can I ask a couple of questions: -
Did you have to change the power plug to the "green" type?
Did you have to make changes in the CCF?
Many Thanks
John
2012 Westminster with RSE and (Focom) DAB
Post #524601 13th Aug 2019 12:07pm
PatrickJamesL
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi John, did you manage to get the DAB+ module working? Looking to try and do the upgrade next weekend as my favourite station has now become DAB+.
Post #533457 7th Nov 2019 9:18pm
