![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 ![]() ![]() |
Anyone got a link please for the Viton O rings please. |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
If you go back a page it's down the bottom.
Yes i saw that Fox, i need a source for some. |
A part No would be a start, need to get two asap. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
Got mine off ebay, is there a link in here?
Thanks Greg, tried that but no luck. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
https://rover.ebay.com/rover/0/0/0?mpre=ht...3062415589
Great, thanks Mike. |
Mine were bought in 2017 which is too old for my ebay history.
I used R&M Bearings and seals'r's for some nitrile O rings for my Tiger 955, worth a look?
O rings arrived this morning and fitted, all looking good so far, just the mess underneath to clean up now, thanks Mike for the link to the o rings. |
That’s excellent service, given the country is in virtual lockdown. |
Talkwrench Member Since: 26 Nov 2019 Location: Lytham St Annes Posts: 17 ![]() ![]() ![]() |
Big thanks to the contributors of the thread, I’ve managed to source the o rings and fit them. I also decided it would be worthwhile changing the gaskets on the oil cooler/filler considering they’re cheap and the potential headache it can cause if they leak oil into the coolant! It’s not like I’ve got anything else to do under lockdown anyway. My gaskets weren’t actually leaking but they weren’t far off, they were very flat and brittle. However it’s still leaking from somewhere. So I’ll get back under it today and see what I can find, I did clean everything the best I could so hopefully it’ll be obvious.
Just a note re mattgage's elbow issue: looks like the same elbow connector to the sump - the one I use to drop my oil.
