Home > Technical (L322) > Very sick TD6 engine, misfire and bad hot start
mjdronfield
These engines are pretty bulletproof. I recon the most reliable ever fitted to an rr.
We will not discuss the gearbox Rolling with laughter 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #341031 6th Aug 2015 5:59pm
miggit
They might be bulletproof, but they aren't numpty proof. I'm just shocked that the engine ran so well with 4 out of 7 nuts missing on the inlet manifold Shocked Still that might explain why it got worse when it was hot, can't imagine that a plastic manifold wouldn't distort with heat. Yesterday I couldn't spell Engineer... Today I are one!
Post #341065 6th Aug 2015 10:29pm
Good news on sourcing the fault Thumbs Up
All be back together soon Smile .
Post #341094 7th Aug 2015 1:35am
miggit
Hi Tim, yes it is a relief that some of the injectors were dud. I did consider doing a leak back test, but decided that having them tested on a proper rig would be better, as they test for worn nozzles too, something that a leak back wont show. Plus they clean them too, so they are as good as new and covered by a Bosch warranty Thumbs Up And not that expensive either, Clean and Test is £17.50 and a recon is £135 and they wave the cleaning cost. That's a hell of a lot cheaper than the prices I have seen on the parts suppliers / fleabay sites, they have been£200 + Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #341115 7th Aug 2015 8:42am
miggit
Very Happy Very Happy It lives Very Happy Very Happy
Put it all back together today, turned the key and Very Happy , a noticeably happier engine. Took it out for a test run and all the torque vibration that I was getting between 30 and 60 has gone Mr. Green
The injectors ended up costing me £410, that was for 4 cleaned and tested and 2 cleaned and rebuilt with new nozzles and valves. And the best bit is I got a full Bosch warranty on the work Thumbs Up
This is the mob that I used http://www.fastlinegroup.co.uk/
Charges are £17.50 + for clean and test, £135 + for full recon, less the cleaning charge. And before you lot say I have overpaid, I had new compression washers supplied too. Yesterday I couldn't spell Engineer... Today I are one!
Post #341334 8th Aug 2015 10:41pm
Top job mate, glad your sorted... Thumbs Up Pete
Post #341336 8th Aug 2015 10:48pm
Videoman1959
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
happy motoring
I am pleased that you got it all sorted... it WAS a saga ! I just hope my 'little' prob stays that way !! Wink 'Knowledge Is Power'
Post #349888 29th Sep 2015 7:20am
