![]() | Home > Technical (L322) > Very sick TD6 engine, misfire and bad hot start |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7916 ![]() ![]() ![]() |
These engines are pretty bulletproof. I recon the most reliable ever fitted to an rr.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
They might be bulletproof, but they aren't numpty proof. I'm just shocked that the engine ran so well with 4 out of 7 nuts missing on the inlet manifold |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Good news on sourcing the fault |
Hi Tim, yes it is a relief that some of the injectors were dud. I did consider doing a leak back test, but decided that having them tested on a proper rig would be better, as they test for worn nozzles too, something that a leak back wont show. Plus they clean them too, so they are as good as new and covered by a Bosch warranty |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8568 ![]() ![]() ![]() |
Top job mate, glad your sorted... |
Videoman1959 Member Since: 11 Apr 2015 Location: United Kingdom Posts: 77 ![]() ![]() ![]() |
I am pleased that you got it all sorted... it WAS a saga ! I just hope my 'little' prob stays that way !! |
